petcock XJ750 seca
Discussion in 'XJ Modifications' started by 82seca750, Dec 23, 2008.
  1. 82seca750
    82seca750 Member
    Greenville, TX
    have to ask is there any way i can run my bike off pri with out hooking you a vaccum
  2. wizard
    That's ok just remember to turn the petcock back to on when you finish your ride, or you could have some flooding problems.
  3. PainterD
    PainterD Active Member
    St. Cloud, Minnesota
    Yes you can, but you won't have vacuum shut off when you shut it down. You will run the risk of having fuel trickling down into the engine oil if the float needles don't do their job.
    Mine had a problem with fuel running after I shut it down once in awhile and it was erratic and I didn't feel like tearing it apart and rebuilding it. I just used a plastic inline shut off valve I bought at a small engine shop. There is just enough room to fit one between the tank and the carbs.
