Pod filters, Exhaust, Dynojets... where is the problem?
Discussion in 'XJ Modifications' started by 514rabbit, Apr 26, 2013.
  1. 514rabbit
    514rabbit Member
    Montréal, QC
    I have spent hours and hours reading the forums about the issues of installing pod filters on XJs (XJ650 1983 in my case), however I still decided to go ahead.
    So I got 4 EMGO filters, Dynojet kit and a 4-into-1 Mac exhaust. I installed the jets as per instructions; enlarged the slide lift holes with the included drill bit, put the cir-clip on the 3rd groove of the new needle, and used the #122 jets (although Dynojet recommends #118 if adding filters+exhaust). Put everything together, synched the carbs and played with the mixture screws until I was happy - the bike is now running like a charm.
    Better sound and noticeable increase in torque.
    Maybe I got lucky, but got it running perfectly fine and quite sure why all the "warnings" on the forum that these bikes will never run properly once you modify them...
  2. quebecois59
    I think you did it the right way by following the instructions you got and using the right settings with the exhaust system you choose to install.
    I may be wrong, but I think most problems occur when one decides to modifiy the exhaust system the way it looks and sounds cool to him and then only after try to find a way to have it run properly without knowing what he's doing.
  3. 514rabbit
    514rabbit Member
    Montréal, QC
    Ah, Je comprends :)
    I didn't want to drill anything in the exhaust, I love the sound of MAC the way it is.
  4. quebecois59
    C'est drôle, je n'avais même pas remarqué que tu es de Montréal! En plus tu es un ti-lapin du 514! MOi je suis dans la Montérégie.
    Bienvenue sur ce forum!
  5. bigfitz52
    Just KEEP AN EYE ON YOUR PLUGS.
    XJs love to run lean... right until they blow up/hole a piston or two.
  6. 514rabbit
    514rabbit Member
    Montréal, QC
    ton nickname est difficile a manquer ;)
    Thanks for the suggestion, I'll check 'em out every few weeks.
    So far (200 km later) they look fine ;)
  7. MercuryMan
    MercuryMan Active Member
    Springdale, NWA
    Tres bien!
    Difficult tasks are often seen as impossible because people without discipline and perseverance take them on. Good Job on doing it right.
    It would be interesting to see how your stats changed. Peak HP and MPG especially. Of course no stat needed for SOP (seat of pants) test!
  8. quebecois59
    Ce serait bien que tu mettes le modèle et l'année de ta (tes?) moto(s) dans ta signature.
  9. 514rabbit
    514rabbit Member
    Montréal, QC
    Unfortunately I forgot to dyno the bike before putting on the mods :(
    However, I will do a dyno run right now out of curiosity. MPG... gotta count that as well, although when I did what I did to the bike I didn't think of MPG much as I expect it to be worse than it was.
  10. Clownman
    Clownman Member
    I did the exact same thing but with a custom straight through exhaust. I have had zero issues, I have checked the plugs and not much has changed with them. I did note that my MPG went way down though, im at about 30-35. But I also ride the hell out of this old girl and she loves every minute of it. She see's triple digits probably about once a week :)
  11. skillet
    skillet Active Member
    SW TN
    NICE to hear posts on pods when done right!!!
    skillet
  12. hogfiddles
    So......let me get this figured out in my own head------
    If a bike has pods put on it, and it doesn't run as well, but the MPG stays up.....that still a bad thing because it has pods.
    Now, here we have a bike that has pods on it. It runs well, but the MPG has drastically dropped, yet people say that the pods have been done right?
    Something still doesn't jive to me.
    Maybe it's I just don't like pods. (except for the set that I have........the brand new ones still in the boxes, still on the shelf. I like them. They look awesome sitting up there.)
    dave
  13. quebecois59
    Clownman reported worse fuel comsumption after he put pods, but 514rabbit hasn't yet. So your conclusions may not apply to 514rabbit's case, we'll see later!
  14. MercuryMan
    Springdale, NWA
    Yea but Clownman has straight pipes and rides like he's trying to blow the gopher out the hole-that will suck anyone's gas.
  15. jmilliken
    jmilliken Well-Known Member
    Dillsburg, PA
    OK... I have went through this argument many times. My understanding of the issue at hand is that the bike may run fine + slightly lean with pods + other mods. However, the bike will not run with 100% factory performance and the lean condition increases risk of holeing a piston.
    I LOVE the way pods look, but any mod that increases the risk of blowing a motor isn't worth it in my book.
  16. 514rabbit
    514rabbit Member
    Montréal, QC
    I am watching my MPG right now and will report later, of course I am expecting to burn more gas than stock. The bike sounds better, looks better, is a little faster has a bit more torque - I think it's worth paying a little more for the gas ;)
  17. 514rabbit
    514rabbit Member
    Montréal, QC
    So I seem to get between 35-40MPG and I do mostly city riding, very little highways. I am pretty happy with this :)
  18. Orange-n-Black
    Memphis Area
    Wow, a pod success story on a XJ! And no mention of valves or did I miss it?
    Anytime performance is added to a vehicle, the mpg's will decrease because of added acceleration and the amount of times said acceleration is applied. Which is probably often. :lol:
  19. 514rabbit
    514rabbit Member
    Montréal, QC
    Well, yes, acceleration is applied quite more often :)
    valves... I kind of took a shortcut on this one. I did check the valves and most were fine, a few were a tiny bit off but I was too excited to ride the bike so I decided to not wait and just ride it. I did order the new shims and will be installing them some time this summer...
    The only inconvenience I have with the pod filters - rain. And it's been raining a lot in montreal lately. I bring a plastic grocery bag with me if it's cloudy outside and I cover the pod filters with it when I park the bike :)
    I don't think the water will get in while i'm riding since my legs kind of cover the filters.
  20. Orange-n-Black
    Memphis Area
    That's always been a problem with pods. Could make a permanent outside flap with the chrome c-shaped airbox covers.
  21. cutlass79500
    lawrenceville georgia
    I am glad everything worked out very strange tho. A mac exhaust does not flow any better then the factory but sounds much better. Pods usually loose low end torque but its a possibility when it hits it stride it seems like it pulls harder. I have been around dynos all my life and have never seen very good power numbers on cv carbs with pods. But maybe you got lucky. No manner if its any faster or not as long as it sounds good any your happy with the vacuum cleaner noise coming from the carbs lol that is all that matters. Me personally i put a header on my maxim x just because i love the sound. Ditched the pods right now it has a pvc airbox with 2 foam filters its a better then just pods but still not like the factory airbox with a k@n in it. When i finish the carbs i will go thru the hassle of putting the air box back in. Best of luck and enjoy it looking forward to the dyno sheets.
    I was lucky when they did my v max they kept changing jets air jets baffles ect it took tnt performance 29 dyno runs to get it all sorted out. Still wasn't happy down low and it had airbox modified but it made most power in this trim so i left it alone
  22. 514rabbit
    514rabbit Member
    Montréal, QC
    I know what you mean and I was expecting worse low-end performance, however, it actually performs a lot better at low RPM than it used to, I am very surprise.
    I think these modifications go case-by-case. Probably the previous owner didn't do anything on the bike and probably when I got it the bike didn't run as well as it should - that's why now I think it runs awesome. It is possible it doesn't run as well as a well maintained stock XJ650, I can't tell, I've never been on another Maxim...
  23. SLKid
    SLKid Active Member
    Troy, Va (Charlottesville)
    I heard no mention of Dyno Results, Plug Chops, or even a Colortune. "Watch" your plugs. Post your chops.
    Something doesnt sound right to me. If you dont keep an eye on it, you may not have a bike sometime soon
  24. 514rabbit
    514rabbit Member
    Montréal, QC
    Plugs look okay so far and unfortunately I haven't had the time for a dyno run. Hopefully it will be done in the next 2 weeks while I have an access to a free dyno.
    I will probably buy new plugs for a plug chop soon as well. Last year's plugs won't tell much...
