Possible bent cam? Ways to check?
Discussion in 'Hangout Lounge' started by smeagol21b, May 5, 2018.
  1. smeagol21b
    smeagol21b Active Member
    hanover,pa
    So trying to get my bike on the road again And some of the valves are out of spec( like .6 if memory serves) @TheCrazyGnat and I are trying to figure out this big gap and are wonder if there isn't a slight bend in the cam somehow? Is there any way we can check this before I resort to buying another cam? And other suggestions for addressing these gaps? Some of you might remember I had snapped a cam chain a couple years ago and had taken it to a shop to have repairs done, they said they the clearances all in specs but they either lied or something else happened considering out of intake and exhaust only one valve was in spec....
    Is that 0.6 millimeters, or 0.6 inches?
    Do you have a dial indicator?
  3. smeagol21b
    hanover,pa
    Millimeters and no I don't believe we have one, I know I don't but not sure about crazygnat...
  4. LarryMc
    LarryMc Active Member
    Lakewood, WA
    A couple of years of not checking your valve lash , depending the miles and how hard you ride, and the valves are surely going to be out of spec but usually tighter.
    With huge clearances your bike wouldn't run at all. Double check your work and use metric feeler gauges.
  5. XJ550H
    smeagol21b likes this.
  6. smeagol21b
    hanover,pa
    The work to the valve was finished beginning of June of last year right before I went up to the CNYCC....that's when the shop said everything was in spec, only got to ride for about 3 month at best so I'm 99.9% sure it ain't from riding lol. And metric gauges were used
  7. k-moe
    If the cam were bent enough to have that large of a gap you'd see the bend as the cam turns. Pull the spark plugs out and turn the engine over by hand slowly. Watch the cam as you turn the engine over.
    I highly doubt that the cam is bemt.
    I highly suspect that the shop was looking at the wrong spec sheet (if they bothered to look at one at all).
  8. smeagol21b
    hanover,pa
    I have a video somewhere of the cams turning I'll give it another look but I don't remember seeing anything like that... Yeah I'm thinking they just threw things together, between that and them having 5 different people work on it and them taking the better part of a year to get it done.... The variance between gaps was pretty wacky too....
  9. TheCrazyGnat
    Central PA
    Here are the valve clearances, for what it's worth. And yes, we were using metric gauges. I did check I1 and I2 multiple times.
    I1: .6 290
    I2: .6 285
    I3: .24. 290
    I4: .17 280
    E1: .04 270
    E2: .09 270
    E3: .16 265
    E4: .15 265
    Smeagol should have a video of me turning the cams ( with my commentary, ha ha). Currently the cams, chain, etc are all off.
    I have no idea if it means anything, but the top cam chain guide is the one that was in the bike, the one below is a good oem one. I can't think of a reason for the guide to have been bent like that in the engine...
    I don't have a dial indicator.
  10. TheCrazyGnat
    Central PA
    My thought at this time is to:
    -check the cam chain tensioner
    -replace the cam chain guides (We have used oem replacements)
    -replace chain (the aftermarket one in there now has some bound up links)
    - set timing
    - check valve clearances again
    - do a compression test
    - go from there
    If anyone has anything else to try/add, we are all ears.
  11. XJ550H
    so with these 2 measurements you need a new head
    I1: .6 290
    I2: .6 285
    look and see if the shim buckets are damaged or valve stems beat short
    measure cam lobes . intake should measure 36.5
    could they have put cams back in wrong place?
    exhaust 35.8mm
    edited incorrect intake cam measurement
  12. smeagol21b
    hanover,pa
    New head?! Dude...you're breaking my heart! (And my wallet!) Is that a surefire thing or could it be one of those other thinng?
  13. XJ550H
    there is no shim replacment listed for your measurments. I would look at valve stems, guides and buckets
    maybe the 2 valve seats can be cut deeper to close the gap
    I do not think it is possible to swap intake and exhaust cams and bike run due to specs I read.
    with the shim clearance you showed the cams coud have worn down . the tips of the lobes would make contact very late putting the force on the ends of the lobes
    did you measure the shims maybe they put them in upside down and wore them down or ground them down
    TheCrazyGnat and smeagol21b like this.
  14. smeagol21b
    hanover,pa
    I know at least one valve is new possible two, I'll call the shop and ask to see if they remember, maybe that's the whole problem! I don't remember if we checked to see if they were upside-down, honestly I wouldn't have thought it would matter so I learned something new!
  15. XJ550H
    only the top of shim is hardened
    Franz and smeagol21b like this.
  16. TheCrazyGnat
    Central PA
    The intake:
    1 - 1.437" 36.5 mm
    2 - 1.437" 36.5 mm
    3 - 1.433" 36.398 mm
    4 - 1.429" 36.297 mm
    I believe it is possible that one of the Shims was upside down, but no more than that. I had to measure intake number 1 because the stamp was completely worn off ( assuming that I couldn't see the label because it was installed upside down and the lobe wore it off). The rest of them had the marking on the bottom.
    They were measured in inches, unfortunately, I don't have metric calipers.
  17. XJ550H
    are those numbers the shim thicknesses?
    decimal point is in the wrong place maybe? or is the 1 actually an I but again 36.5 mm is almost an inch and a half thick.
  18. XJ550H
  19. TheCrazyGnat
    Central PA
    Sorry, those are the intake camshaft lobe thicknesses (as l measured them).
  20. XJ550H
    upload_2018-5-5_22-5-33.png seca650 cam spec so cams are good
  21. XJ550H
    it should be possible to have the out of spec intake valves cut deeper into seats or refaced to correct the problem of not being able to reshim
  22. TheCrazyGnat
    Central PA
    I have heard that it might be possible to put a shim in under the bucket. I've never had the need to do that, so I've never looked into it. Would that be a possibility?
  23. k-moe
    No. Shim under bucket systems are different, and there is no provision for putting a shim under the existing bucket. Even if there were it would be a bandaid (a cheap, off-brand bandaid that would fall off after it got wet).
    It is possible (but extrememly unlikely) that the valve seats were redone at some point, but not set deep enough. Another possibility is that some DA PO tried to adjust the clearances by grinding the valve stems (like on a a lanmower engine).
    I think it's adviseable to pull the head for inspection, or just get a replacement head.
    hogfiddles and smeagol21b like this.
  24. Toomanybikes
    Tsawwassen bc
    Lobe size is not the problem here. Lobe size it for lift it's the base size that determines clearance. So possibly the base circle of the cam is worn creating the big clearance.
    A picture of the opposite side from the lobe may tell a story.
  25. hogfiddles
    Shims are hardened both sides. That's not the issue here. Do NOT put shims under the buckets!!!!
    I still am suspect of the valves themselves.... seems like they're too short.
    Both crazygnat and I are still on this, too.
    Post the video clip of the "snap", as well. (Didn't we narrow that down to sticky chain links though)
    Dfox
  26. TheCrazyGnat
    Central PA
    Apparently the shop replaced at least one valve. They had to send the valve out to get the seat cut, then all of the valves were lapped and supposedly in spec, for what that is worth. I can't imagine everything was in spec and in three months of riding things went this horribly awry.
    I'm sorry, I'm not quite following. Are you saying to measure the "width" of the lobe (if we were to call what I measured before the length)? Or the round post that rides in the bearing surface of the head(I'm not sure of the correct terminology here)?
    @hogfiddles : We were satisfied that the chain "snap" was due to the bound up links, I think it would be helpful for Smeagol to post the video to show the cam rotating. I didn't notice anything wrong, but maybe the better trained eyes here can. Also, did you see the picture I posted earlier? The front cam chain guide was bent all out of whack. I don't know if that is a symptom or contributing factor to the chain issue.
  27. hogfiddles
    @hogfiddles : We were satisfied that the chain "snap" was due to the bound up links, I think it would be helpful for Smeagol to post the video to show the cam rotating. I didn't notice anything wrong, but maybe the better trained eyes here can. Also, did you see the picture I posted earlier? The front cam chain guide was bent all out of whack. I don't know if that is a symptom or contributing factor to the chain issue.[/QUOTE]
    Yeah, that's what meant.
    I don't recall a pic of a bent chain guide.....
  28. TheCrazyGnat
    Central PA
    I attached the pic on the previous page of this thread.
  29. Toomanybikes
    Tsawwassen bc
    Lobe height is lift( lobe pushing down on shim and bucket) base circle is diameter of cam with no lift. Hope that makes sense.
  30. k-moe
    If a valve stem were bent, or had a burr, or if the valve guide was damaged or not of the correct size, that could cause the valve to hang up, and clearnace would be excessive.
  31. TheCrazyGnat
    Central PA
    I've got you now. Sorry,I can be a little slow on the uptake sometimes.
  32. TheCrazyGnat
    Central PA
    I would not be one bit surprised to find out the issue is with the valves; I have been less than impressed with the work I have seen so far.
  33. smeagol21b
    hanover,pa
    With the shop that did the work it's actually extremely likely in my opinion that the shop didn't cut the seats deep enough... Are there measurements or something to check that?
  34. smeagol21b
    hanover,pa
    I'm trying to figure out how to attach the file, I could send it to you in a text if need be but yes there were several sticky links in the chain...
  35. smeagol21b
    hanover,pa
    To say the least! I shouldn't laugh but yeah not the best work....
  36. k-moe
    There are specs in the service manuals. AFIK they are correct, as both the Haynes and Yamaha manuals agree on the dimensions.
  37. Minimutly
    Minimutly Well-Known Member
    West Wales, uk
    Too deep / not deep enough? So which is it here? From the skim read I've had I think I understand excessive clearance, so the only likely possibility is seats cut too deep, valce refaced ecxessively, or they shortened them at the stem tip.edit to agree with valves sticking open possibility.
    If you can't get a thick enough shim it's head off time, do some looking, some comparing, and some measuring.
    Your head may be fine, if not, a replacement good one not too expensive. Not the end of the world.
    Oh, and to be pedantic, the "width" or measurement across the narrow bit of a cam lobe cannot be guaranteed to be the base circle diameter, it depends where the opening and closing ramps are. And from this, the measurement across the wide bit is not the lift. Lift is the difference between half the base circle diameter and the width across the lobe, once you've accurately determined the base circle diameter.
  38. k-moe
    For there to be excessive clearance the seats would have to have been cut too shallow.
    Refacing the valve excessively would result in tighter clearance.
  39. smeagol21b
    hanover,pa
    That's what I thought but I've never messed with an engine this much....yet! I'm going to look into getting a valve seat cutter.... I know the shop owner had the head sent out twice to be recut and the finishing "work" was rushed to completion.... So it would come as no surprise is they just got sick of dealing with it and slapped it all together enough to run it....
  40. Minimutly
    West Wales, uk
    I can honestly say I'm not drunk, so why I wrote that drivel I don't know. Please ignore my post..
    Shall I try again?
    Excessive clearance - don't see it anything to to do with cutting seats, if the seats were fine before. So, the cle to this could be that the valve was sent away to be refaced - did the use oversize valves ground down? Are they available - 600valves perhaps?
    A thousand appologies again.
  41. XJ550H
    do you need an XJ650RJ factory service manual?
    all your specs are listed in the fsm for valves seats and cams
  42. XJ550H
  43. smeagol21b
    hanover,pa
    Couldn't tell ya man, other than they are aftermarket... Extent of my knowledge there, the shop took almost a year to "fix" my bike
  44. XJ550H
    uploaded a manual for you if you want it check your inbox
  45. smeagol21b
    hanover,pa
  46. XJ550H
    mark the links see if it is the same link , or is the sprocket tooth causing that action
  47. Polock
    that's normal. the valve springs, lifters and shims get to a point where they push the cam forward, the same direction that the chain was pulling it. it gets slack but it didn't jump a tooth or the cam would be out of time. it just happens to be as that bolt goes by.
    the description you gave sounds like a rod bearing to me
  48. Franz
    I did not know that XJ 550H but I made sure the numbers on the shim were facing the buckets when I changed my shims.
  49. TheCrazyGnat
    Central PA
    Sorry guys, that video was about three weeks ago when we were working on it, the cams and chain have since been removed. We were planning on putting on a new chain, checking the tensioner, putting in New guides, then putting everything back in making sure to torque everything down correctly. The hope was that we would measure the valve shim clearances and all would be reasonably close to in spec.
    I thought maybe the video showed the cam more straight on than it did, I guess I was mistaken. We did peek down in there and turned the crank after wremoving the cams to see if any of the teeth on the crank and nothing appeared bent out broken.
    @Polock : what leads you to believe it might be a bearing?
  50. Polock
    i don't know, i think my threads got wound into a rope. disregard that
    smeagol21b and chacal like this.
