Problems witth 750RL
Discussion in 'XJ Technical Chat' started by Jakub, Feb 25, 2011.
  1. Jakub
    Jakub New Member
    Ontario, Canada
    Hello! This is my first bike and I'm not the most knowledgeable when it comes to bike repair but it's a 1984 750RL, I bought it used and it was sitting for about 8 years, the owner said it was running perfectly before he stored it. I fully cleaned the carbs with boiling lemon juice and tried to start it, the engine made a sound like it was about to start, but there was no spark so it didn't, (spark plugs look in good condition). All the lights, signals, and electronics work fine. The ignition coils resistances read 5.5 at Rx-1 primary coil and 200 at Rx-100 secondary coil, are these the right numbers? Also is there any way to find out if the ICU is working properly?
    Thanks in advance!
  2. JeffK
    JeffK Well-Known Member
    Just North of Annapolis MD
    Wow, that is a RARE bike from what I remember...there were less then 1000 ever built. I don't think it ever sold in the US. I friend of mine brought one to me many years ago that he had brought with him when he moved here from Ontario without spark and we found a bad connection in the wiring connectors. It's very similar to some of the bikes sold here but I wouldn't use thier procedures. You can always check PDF town for a manual is you don't get the help that you need, here.
    Good luck, you def have a special bike there. Your sig doesn't show where you live but are you in the US, AU or Canada?
    jeff
  3. gunnabuild1
    gunnabuild1 Member
    Ive got one of those as well cant give you any info on your numbers but at 35000k you would have to be very unlucky to have your tci crap out but like was said earlier where are you?
  4. Jakub
    Jakub New Member
    Ontario, Canada
    Thanks for the help, and I'm in Ontario, Canada. I found the manual that the previous owner gave me and for the ignition coils it says: 2.5ohm +- 10% @ 20'C for the primary coil and 11kohm +- 20% @ 20'C (degrees Celsius) for the secondary coil so looks like i'm going to have to replace those.
