PROJECT 900
Discussion in 'XJ Technical Chat' started by wizard, Jun 10, 2009.
  1. wizard
    It's home, I think I'll take Fitz's advise & get it running before I sell the 650.
  2. dwcopple
    dwcopple Active Member
    bay city, michigan
    wow, that rack killed it.
  3. mirco
    mirco Member
    LaGrange Ohio
    Very cool bike! I love it! I even like the rack. If it were mine I would probably cut the sissy bar down several inches and lean it back so it blends in more with the lines of the bike. But those racks sure are handy.
  4. hammerheadx
    hammerheadx Member
    Binghamton, NY
    Very first order of business...
    Remove that abortion that's hanging off the back of that beautiful bike.
    Then melt it down and make toilet parts out of it.
    On second thought, never mind. Just scrap it.
    I wouldn't even want to take a crap on that hideous thing.
    Cool score on the bike though.
    Any idea why it's not running?
  5. baz666
    baz666 Member
    Washington, DC
    Did it come with the small fairing? I wouldn't worry about the rack too much. Just cut down the sissy bar a ways. I have a small rack on my 900 and they're very handy. I also put mini-stalk signal lights front and back on mine. The stock signals (you appear to still have the stockers on the rear) are big as lunch boxes and twenty times as ugly. I know it's akin to working for Satan as far as some forum members are concerned, but I put airpods on my 900. It had no airbox when I got it. The flasher driving the signal lights also seems to be a weak point on some XJ's. It didn't work on my 650 Maxim either. So I rewired car-type flash units and they work real well on both bikes. Cheap too, about 4 bucks each.
  6. stereomind
    stereomind Active Member
    Tulsa, OK
    That rack... As Mr. Zappa once said: "Do yoseff a favum 'n DON'T USE IT!"
    Great looking bike, Wiz. I'm jealous. Now get to polishing!! :mrgreen:
  7. wizard
    Ans:
    Rack is history.
    It did not come with a fairing.
    I intend to fit small turn signal lights.
    No compression on 2 pots, I will start to investigate this W/E.
    Wiz.
  8. dpawl31
    dpawl31 Member
    NH, USA
    Don't trash the rack, sell it.
    So many nerds out there willing to buy it haha.
    Interesting pipe... wonder how it sounds.
    Wonder if they researched what to put on - or just threw some crotch rocket exhaust on.
    I dig me the 900's as far as the power/weight ratio goes. But did they ever make a 900 MAXIM?
    Not one for the SECA riding position for a daily rider.
  9. hammerheadx
    hammerheadx Member
    Binghamton, NY
    second order of business:
    Move the horns off the forks and put them on the frame above and behind the oil cooler. Get a set off an XJ750.
    Third order of business:
    Maybe have the right front turn signal aim forward?
    :lol:
    Provided the engine is salvageable, that's a heck of a find and i'm jealous.
  10. Hillsy
    Hillsy Member
    Apart from the 4 into 1 (and the "rack") that's pretty damn original.
    Nice one :wink:
    EDIT: on second look, I'd say those rear shocks aren't original (and a tad too short) - how much space is under the rear wheel when it's on the centrestand??
  11. wizard
    12 mm, what should it be?
  12. Hillsy
    Hillsy Member
    That sounds about right, but the rear end looks pretty low (like it might bottom out). Maybe the shocks are sagged??
    Measure their length eye to eye when it's on the centrestand v's the sidestand. Should be about an inch difference.
  13. redcentre003
    redcentre003 Member
    Nice looking bike...mainly because it looks exactly like mine right down to the black and red color scheme.
    I must drop by one day on a weekend when the weather gets out of this cold snap. I had to ride in HAIL a couple of days ago. It's like shotgun pellets hitting your helmet!
    Any questions or the need for an additional pair of XJ hands, just let me know and if i can I will assist.
    Cheers.
  14. redcentre003
    redcentre003 Member
    Cheers.
  15. wizard
    Thanks Red, you can start now :)
    I like the way the elec' equipment is laid out.
    Note the original tool kit, but I think I might need it.
    Test # 1, shop air to each cylinder, on compression stroke, blows the piston down, exhaust stroke, blows air out the exhaust, inlet valve open, blows it out the airbox, I can't see much wrong with that.
    I don't have the comp' results that the vendor carried out & why he said 2 pots had none. :?
    Should I replace the valve cover while testing the comp' will I get covered in oil?
  16. bigfitz52
    I spun a 550 over ONCE with the valve cover off. Once. I'll never do that again; I had NO IDEA how much oil is actually up there... (it went everywhere...)
    REALLY cool find; I'm jealous too.
    The rear does appear to be lower than it ought; US-market bikes had remote-reservoir shocks; I suspect those are aftermarket and shorter than stock.
    The turn signals someone put on the front are similar to the ones I put on my '83; they're from the early nineties FZ, FJ and Radians. I got K & S "pattern" units from chacal.
    Good strike.
  17. knuts2a
    knuts2a Member
    Looks like a good start. My rack supports hug the seat line and bolt onto the top shock bolts, that one does hang low, does look daggy. I use mine for commuting so the rack bag lives on it, amazing what you can fit in it. The pipe looks neat, much nicer than mine, probably sounds better to! Was -3 going to work this morning, so i love having a fairing. Whats planned for it?
  18. mcrwt644
    mcrwt644 Member
    Winchester, VA
    that is one cool looking bike...figures, all the really cool bikes ended up overseas
  19. wizard
    Eye to eye, on centre stand, = 12 1/2"------ on side stand, = 11"
    What do you recon?
  20. Hillsy
    Hillsy Member
    Sounds like the shock springs have sagged, or the springing is too soft. Have a look under the rear guard to see if there's any evidence of the tyre rubbing. Then sit on the bike (maybe 2 up?) and jump up and down to see if it's going to bottom out.
    If it doesn't, it will be OK - your rear end will just be a little low.
    But it sounds like you could do with some new (possibly heavier sprung) shocks.
  21. wizard
    Hillsy, these shocks are pretty beat up & would need a fair bit of work to bring them back, I would like to fit new aftermarket shocks, as you say stiffer & longer, to sit the back up some, don't know what the options would be, any ideas?
    I am going to check the valve gaps now & will post up the figures, then do the compression tests again.
  22. dpawl31
    dpawl31 Member
    NH, USA
    Anyone ever put air ride adjustable on the rear of an XJ? That would be real nice on a 900.
  23. Hillsy
    Hillsy Member
    Here you go:
    http://www.ikonsuspension.com/content/a ... tion.shtml
    This is the mob that took over Koni shocks (Ikon is an acronym of Koni...clever chaps...)
    XJ900 is listed as 7610-1506 - which is 307MM eye to eye. Sounds pretty close to what your current "extended" shocks sit at (but no doubt the new springs will keep the back up).
  24. redcentre003
    redcentre003 Member
    Hi,
    I don't have the necessary equipment but when I did an initial compression test on my bike I just left on spark plug in and turned the bike over manually using a spanner on the square end on the timing plate located on the left hand end of the crankshaft. Just undo the four screws, pop the cover off and get the right sized spanner and turn anti-clockwise (i.e. toward the front of the bike if the spanner handle is vertical). If you're feeling resitance then that's compression. It's a start at least. A proper compression test will tell you the numbers and whether anything is really wrong.
    Not sure how many miles/kilometres on the clock but I'm guessing that it might need new rings at least. Once you've established it's got good compression and it runs then you could possibly make do with that for a little while however In my view I reckon if you've got the time then I'd take the head off and have a look inside. Are all the pistons OK (mine were fine but were caked in carbon). Are the rings OK (mine looked fine but the bike kept fouling plugs - the rings were not OK at all). I replaced the rings eventually.
    I also replaced the bottom gasket and you'll need a new head gasket (it is possible to re-use the head gasket by refurbishing it with copper spray) but either through Yamaha (a new head gasket will cost around $130) or through ebay (a whole gasket SET will cost around the same) might be worth considering.
    Any specific issues post them here or send me a PM and I'll see if I can advise.
  25. wizard
    Valve clearance, bad numbers :cry:
    1-----IN .006--F255--N250-----EX .006--F280--N270
    2-----IN .008--F255--N250-----EX .006--F280--N270
    3-----IN .005--F260--N250-----EX .005--F270--N255
    4-----IN .005--F260--N250-----EX .008--F265--N255
    F = Fitted----------N = Needs
    SO: IN1 to EX4---IN2 to EX3---EX3 to EX2
    Need new: 3# 250---1# 245---1# 270
    Anyone double check for me?
    Should be:
    IN 0.11 - 0.15
    EX 0.16 - 0.20
    No point checking the compression again until I sort this lot out.
  26. bigfitz52
    Looks good to me but I'd use all new shims and not swap the old ones over to different pots. #3 exhaust is downright scary.
  27. wizard
    You XJ900 guys, are these bars stock? they have a great feel, retro.
    Pic 2 typical XJ fuse box.
  28. dpawl31
    dpawl31 Member
    NH, USA
    Those look like Fitz's Euro bars?
  29. Ltdave
    Ltdave Member
    you can just see the bars on my bike...
    they are 2 or 3 piece aluminum. they are adjustable in a couple of different planes...
    it certainly looks like your bars are original based on the clamps on the triple tree...
  30. TIMEtoRIDE
    I blew out a 900 shock and fitted the air shocks from my 650 Turbo.
    They are longer, with the bike on center stand the back tire is barely off the ground. Riding with one dead shock was no fun.
    Wizard, your bars and gauges are correct for Australia.
  31. railtrolley
    railtrolley Member
    Melbourne, Australia
    What year is your 900? I think there was an unfaired version available, which yours appears to be.
    The forks look like they have been replaced with later ones from the 86-88 year model. They are the same as mine, which are non-air, no anti-dive. If you want to get your fork top bolts undone, I can recommend using a 17mm Allen socket driver from an industrial supplies shop. Got my top bolts undone no worries.
    The smooth vented front brake discs are on the 83-84 model. The 86 - 88 have slotted non-vented discs.
    Was your rack a Ventura or a Gearsak?
  32. wizard
    Railtrolley, the bike is '85, the rack was Gearsak, the plastic coating was coming off, so I recycled it.
    Lt, your bars are what is shown in my manual, that is why I asked about mine.
    The rear shocks are air assisted.
  33. railtrolley
    railtrolley Member
    I had a Gearsak on my previous XJ900RK. Sometimes I banged my toe on it while I was swinging a leg over. I'll probably just use a tank bag on this one. Racks are useful, but ugly.
    The bars on yours are different from the faired model. Mine has 2 one piece non-adjustable bars bolted straight to the top fork clamp with 10mm Allen bolts. No clamps used.
    I'm dismantleing my forks at the moment, which I should be doing now, but it is very cold outside.
  34. wizard
    Fuse box upgraded.
    I know I have a 20A in the main, have to get a 30A Monday.
  35. chacal
    Looks like one of these:
    MODEL NAME: XJ900N
    STREET NAME: 1985 XJ900
    MODEL ID CODE: 1FX
    FRAME ID: 1FX
    SERIAL NUMBER STARTS AT: 000101
    NOTE: 891cc engine, no fairing, no anti-dive.
    I believe they called these the "Naked" models since there was no fairing, and originally used those style handlebars rather than the "infinitely adjustable" versions as placed on the earlier models.
    Use the big 8" headlight, too, it appears.......
  36. bigfitz52
    Wiz; from the closeups, I'll bet a lot of what appears to be rust on the frame, etc., turns out to be crud instead. I see the same color residue on plastic parts and they don't rust.
    Super cool bike I'm jealous.
  37. albear
    albear Member
    <a href="http://maps.google.com/maps?q=-83.979259+
    Hi wiz,your bars look the same as mine,which is excatly the same.
    gheers albear
  38. wizard
    Spot on as usual, Len.
    Matching mill & frame #s 1FX 000268.
  39. wizard
    I put 15 lbs of air in there & they measured 12 1/2" on & off the stand, but if I am going to reuse these I need seals, does anyone reconize the make? I can't find a name.
  40. wizard
    Clutch switch refurb', kids don't try this at home :D
  41. dpawl31
    dpawl31 Member
    NH, USA
    Is that a regular clutch switch? Are all XJ clutch switches the same?
  42. wizard
    Some have a round body & some don't have one at all.
  43. chacal
    And some of the round ones pop (snap) in place, and some use a screw.....
  44. wizard
    Update:
    Valve shims replaced.
    Compression test: W.O.T. & air filter removed.
    DRY:
    #1-50 PSI
    #2-0
    #3-110
    #4-50
    WET:
    #1-120
    #2-0
    #3-200
    #4-180.
    So: 1---3---4= rings.. 2-valves, yes I did check there was a pistion in there.
  45. albear
    albear Member
    ok stupid question #1.
    what does W.O.T. MEAN,
    iam thinking it means without tank?
    :oops: :oops: :oops: :oops:
    cheers al bear
  46. AndrewM
    AndrewM Member
    Cebu, Philippines
    It's not a stupid question at all. Means - Wide Open Throttle.
  47. dpawl31
    dpawl31 Member
    NH, USA
    Having the throttle plate open allows nearly unrestricted airflow in, so the cylinder can get all the air it needs to compress fully.
  48. Hillsy
    Hillsy Member
    Zero on #2. Really? 8O I'm thinking it might have a blown head gasket as well or a hole in the piston (hopefully not :cry: ) - you should get SOME reading out of a cyl if the valves are close to closing.....
    albear - WOT = wide open throttle.
  49. wizard
    Well, as they used to say in the French Revolution, "off with it's head" :cry:
  50. bigfitz52
    the suspense...
