Pros/Cons for using the carb diaphragm/air jet cover plate?
Discussion in 'XJ Technical Chat' started by jwh7, Sep 1, 2007.
  1. jwh7
    jwh7 New Member
    Central IN
    I've been rebuilding my XJ650RJ's carb, and found (along w/ several other problems...) that their were no air jet plates. After perusing the forums here today, it appears that these plates weren't necessarily used on all Hitachi's...I'd initially assumed a previous owner had removed them as a 'performance improvement'; so I'm trying to surmise if I should use them. I got a free set of them off a 750RJ's carb set, so they are available to me. Only thing I can think of is that they stabilize the air pressure for the air jets...
    And while I'm here...with my rebuild, I needed a couple jet needles...and the place I went to didn't have any 650 needles (Y-10) in good shape; but did have a whole set of 750's (Y-13) which I got. I'm using my original springs, and no shims (the 750's had a shim, and lighter springs); so I'm wondering if you think that would have a big effect? What does the Y-1* indicate; a taper/slope or something? The needles certainly looked the same... :)
  2. Robert
    Welcome first off, you happened to find some of the best XJ carb people around.
    As for the covers, I have them in place on my units but I also understand they were omitted in later models with out a change in jet sizes, leading me to believe they are unneccessary for performance. Take your pick, run them with and without and see what you notice. Report your findings.
