Question About Float Bowl Needle Valve
Discussion in 'XJ Technical Chat' started by moshumi13, Feb 13, 2012.
  1. moshumi13
    moshumi13 Member
    Salisbury, MD (near Ocean City!)
    How important is it that the spring inside the needle valve still function? Can I still set my floats without the spring working. The spring is inside the needle valve and allows the tiny button that contacts with the float to depress about 1 cm. If it's not uber important I'd like to go ahead and reuse them. This is concerning a Mikuni BS32 carb from a '85 FJ600. Should be very similar to BS28 model.
    Nevermind. I just set the floats to my known good needle valve and then installed the floats with the stuck spring needle valves and they measured the same. I think the spring adds extra closure pressure. Will find out when I put the carbs on the bike. Still waiting on key and battery, though.
  2. tskaz
    tskaz Active Member
    Saint Louis, Michigan
    It would not be good to reuse a needle that doesn't function correctly.
    The float rises to presss that spring in and without the tension of the spring the valve will never seal properly.
  3. moshumi13
    moshumi13 Member
    That sucks. Guess I'll have to get some new ones. At least the float height is already set.
  4. bigfitz52
    Be sure to double check it after replacing the needle valves; it doesn't take much variation to throw the float levels way off.
  5. tskaz
    tskaz Active Member
    +1
    New needle valves are usually about 1mm longer and that's about all the variation Yamaha allowed for most carbs.
