Question about my Hitachi carbs
Discussion in 'XJ Technical Chat' started by jcro61, Jun 5, 2014.
  1. jcro61
    jcro61 Member
    Massachusetts
    I am cleaning the carbs on my 1985 xj700, I had a question about the ports on the carbs as the bike did not come fully assembled and the manual I have makes no mention of what these are. From what I gather, the center is the fuel supply, the two lower are vents.. but what are the ports at the top on each carb body? I tried searching the net and no dice.. I attached a photo of the ports I am speaking of. Thanks in advance for any help.
  2. Bushy
    Bushy Active Member
    XJ700 Models:
    Years & Models: 1985-6 XJ700 air-cooled models
    Carb Manufacturer: Hitachi
    Carb Series: HSC33
    1985 Carb Model ID: 1FG00 (N models) or 1JJ00 (NC models)
    1986 Carb Model ID: 1NH00 (S models) or 1NK00 (SC models)
    Main FUEL Jet Size: #107
    Pilot FUEL Jet Size: #36.5
    Main AIR Jet Size: #70
    Pilot AIR Jet Size: #210
    AIR COMPENSATOR Jet Size: not used
    Starter FUEL Jet Size: #36 (non-replaceable, in float bowl)
    Main jet NEEDLE ID: #Y-20
    Main needle JET Size: #3.2mm (the main needle JET is also known as the "power valve" or "emulsion tube").
    Fuel Level in float bowls: 1.0mm +/- 1mm (.039" +/- .039")
    Idle RPM's: 1,050 rpms
    Most likely ^^^^
    From what I know they are vents to atmosphere that have a tube from them running back from the top of the carbs. Had a quick look for more info but didn't find it. Search for hitachi HSC 33 carbs.
  3. bmarzka
    bmarzka Active Member
    Northwesten PA on Lake Erie
    Just took a look at my bike. Those ports have hoses attached that run back to between the engine and air box. I believe Bushy is right about them being vents.
  4. jcro61
    jcro61 Member
    Massachusetts
    Thanks for the response guys. I will just put some hose on them and route it somewhere
