Question regarding the location of the flasher relay
Discussion in 'XJ Technical Chat' started by kc0jov, Jun 25, 2009.
  1. kc0jov
    kc0jov New Member
    Saint Louis, MO
    Hi all,
    Where is the flasher relay located on a 81 550 Maxim?
    Thanks in advance!
  2. SQLGuy
    SQLGuy Well-Known Member
    Don't know for sure, but if it's the same as the 750's, then it's attached to the bottom of the frame under the tank.
  3. kc0jov
    kc0jov New Member
    Saint Louis, MO
    Thanks for the speedy response! I knew I could count on this site! I'll check it out when she cools off from riding (might be awhile as it is still 92 degrees outside.)
    Thanks again!
  4. kc0jov
    kc0jov New Member
    Saint Louis, MO
    SQLGuy,
    It was right where you said it would be :) Thanks again!!
