For Sale random parts laying around the garage
Discussion in 'For Sale, Trade/Swap, Wanted' started by moellear, Dec 15, 2015.
  1. moellear
    moellear Member
    Lima, Ohio
    A little about me since this site layout has changed and I'm not as active on the site nowadays. I miss the days when Bigfitz52 was around multiple times a day posting to help others - I got a lot of help from him. Been on here since 2008 and ride my two XJ's as often as I can. The best part? I'm younger (by 5 years) than my bikes & bought them non-running, of which one I rebuilt the engine with new rings and learned a lot throughout the process.
    Anyhow...
    As the title states, I have limited space and would like to tidy up the garage. A lot of these parts have never been in use by me nor do I have plans to use them so I'd like to see them go fairly cheap. If you'd like to view pictures I most likely have them on my photobucket site. If you see other items in the pictures feel free to inquire about them too. Thanks guys
    http://s1115.photobucket.com/user/moellear/library/misc parts for sale 4-29-2012?sort=3&page=1
    • oval "Eagle" aftermarket, brand new set of mirrors - $10
    • H2 & H3 header pipes from 650 maxim exhaust - $10 each or $15 for both
    • 550 valve cover bolts - 8 long & 4 short stems - $3 for all 12
    • original handle bar grips, both left & right - $3 for one or $5 for both
    • straight (drag style) handlebar good for a bobber project - $10
    • two (2) U-bolt rubber covers - $1 each or $1 for both (not a typo...)
    • stator cover with wire attached - $5
    • maxim 650 gear shift cover - $5
    • maxim 650 rear peg bracket mounts - $5 for both
    • YICS left side engine cover - $5
    • engine mounting bolts from maxim 650 - $0.25 a bolt (?) I'll work out a deal, just let me know what you're looking for
  2. moellear
    moellear Member
    Lima, Ohio
    Forgot to mention that shipping will be separate at buyer's expense. Shouldn't be a surprise but just wanted to clarify. Also I don't have a smartphone (even bigger surprise to some I'm sure since I'm a millennial) but I can also send pics via text at 41995322872.
    Edit: grips are sold.
  3. joejr2
    Santa Fe,NM
    I'm interested in the 650 gearshift cover and the stator cover. Is the stator cover from a maxim
    650 as well?
  4. moellear
    moellear Member
    Lima, Ohio
    Yes, stator cover is from a maxim 650. I can snap a picture of each for you and send it via text message or post on here, later this evening if you'd like!
  5. moellear
    moellear Member
    Lima, Ohio
    With some elbow grease and polishing these covers would be in excellent condition. The grime you see is just grease - look at the gear shift cover along the left side where a vertical mark is: that's from the oil on my finger just rubbing across. No deep gouges or scratches either. $5 each
  6. joejr2
    Santa Fe,NM
    I'll take the shifter cover and the stator cover at $5.00 each plus $15.00 for shipping.
    p.m. me your e-mail address and I'll send you a paypal notification. That is, If you
    have a paypal account. If not p.m. me your home address and I'll send a usps money order.
    I'm also interested in a clutch cover from an xj maxim if you have one of those.
  7. Coty
    Coty Member
    Frisco city, Alabama
    Do you still have the headers? How good of shape are they in.
  8. Coty
    Coty Member
    And is it all 4 or just 2? I'm attempting a custom exhaust project and I'd like to keep my Stock headers in case I don't like how it turns out
  9. moellear
    moellear Member
    Lima, Ohio
    Yeah sorry its only the two middle headers. If you're still interested I can snap pics. They do have surface rust but not severe.
  10. Coty
    Coty Member
    Ok I'm hunting all four. How bad of shape are they in?
  11. Coty
    Coty Member
    And how much for the 2 shipped?
  12. moellear
    moellear Member
    Lima, Ohio
    The two headers are in okay condition. Like I said, there is rust on the inside curved portion of each pipe but again, I haven't touched these pipes in several years so I'm sure if you took some polishing techniques (soda/coca-cola soaking, ever read into that?) some of the rust would go away. The outside curved portion when looking at the pipes mounted are shiny. Also notice on H2 pipe (the left one shown in pictures) there is a small indent about the size of a quarter near the bottom. I'll reduce the price - $10 for both. I'm looking into shipping costs which should be about $13 for shipping to 36445 but you never clarified so that was only a guess on my part. If you want them, send $23 via paypal to my email aarmoeller@gmail.com & I'll get them out asap!
  13. moellear
    moellear Member
    Lima, Ohio
    Never received the paypal money. I've replied to you with a p.m. with an email address and the package is ready to be shipped, just waiting on you to provide an address and the $ of course!
  14. Coty
    Coty Member
    I sent you the $$. Is there by any chance that the two middle headers can fit in any of the exhaust holes? Since I'm building the exhaust on it I may have to find the other 2 somewhere else. But Im definitely getting these 2.
  15. moellear
    moellear Member
    Lima, Ohio
    Update: both header pipes, original handle bar grips, stator cover, and gear shift cover are sold.
  16. hogfiddles
    City the pipes have individual "twist" and angles. The ends themselves are all the same, so they all will 'fit' in other locations, but you will end up with 'finagling' to get pipes from mismatched locations to fit well.
    That said, if you're building your own, it won't matter as much, but keep in mind that if your exhaust gas analyzer port bolts actually do work (aren't seized/broken off), you'll want to keep then in original positions so you can easily access them ( if you actually use them)
    Dave f
  17. Leblanco
    Leblanco New Member
    Alberta
    Did you still happen to have the valve cover bolts? I'll take them all
  18. hogfiddles
    You did notice this is over-year-old, Right?
  19. XJ550H
    Moellear was at the site today maybe he can clear up what he has left
    or Leblanco could start a conversation with him
