Rear Tire Question...
Discussion in 'Hangout Lounge' started by tdeir70, May 31, 2008.
  1. tdeir70
    tdeir70 Member
    Gananoque, Ontario, 1000 Islands, Canada
    ...Is there any benefit(s) to having a larger rear tire than the stock size? Any pros/cons... Just a curiosity at this point. You see these Gixxer's, etc. that have these Mammoth boots on the back and wonder. Not to compare decades in technology; however larger rear tire may improve handling?
  2. Jim_Vess
    Jim_Vess Member
    Lafayette, CO
    A larger than stock tire on the stock rim will offer no handling improvements and may even diminish handling. Putting a tire on a too narrow rim deforms the tire profile.
    Current sportbikes run 180 or 190 width tires on 5.5" or 6" rims specifically designed for that size.
    If you choose to use a bigger than stock tire, it's best to get a rim the tire fits.
  3. MiCarl
    And a different motorcycle to go with the rim because you aren't going to get a wider rim alongside the driveshaft.
  4. Jim_Vess
    Jim_Vess Member
    Lafayette, CO
    [quote="MiCarl]
    And a different motorcycle to go with the rim because you aren't going to get a wider rim alongside the driveshaft.[/quote]
    You're right, the shaft drive could pose a problem. Clearance issues could limit your selection. That would also hold true for putting a wider tire on the stock rim.
    I'm not sure about the XJ's, but I know you can get wider rims for the shaft-driven V Stars.
