Rear Wheel/ rear pin
Discussion in 'XJ Technical Chat' started by Gunthersavage, Jul 24, 2021.
  1. Gunthersavage
    Gunthersavage New Member
    Fort pierce, Florida, USA
    Hello! I bought this 1985 Yamaha Maxim X 700cc
    I’m discovering some small issues. This I can across and have questions:
    1.) why would there be a zip tie?
    2.) how can I make this correct/proper?
    3.) should I be worried about this?
  2. Toyobaru866
    Toyobaru866 Active Member
    Netherlands
    It looks like a bolt in the axle? And the zip tie to hold it in place? Someone has been creative over there... Take ik out and put in a cotter pin of the right size (one that just fits the hole) Check your bike for other creative solutions...
  3. Toyobaru866
    Netherlands
    Oh no, brain fart... The hole is just for sticking in a screwdriver to pull out the axle so nothing has to be in there. Can you make a better picture of what's going on there?
  4. Toyobaru866
    Netherlands
  5. Toyobaru866
    Netherlands
    What it looks like on mine.
  6. Brent NZ
    Brent NZ Active Member
    Tauranga, New Zealand
    The pin / clevis pin and zip tie are doing nothing and can be removed. The axle is held in place by the clamp-type arrangement on the swingarm.
  7. XJ550H
    the axle is a large spacer setting all the spacers and bearings to proper leangth when torqued.
    the hole in the axle is where you put a rod when removing or installing the axle
    the right side of frame is a clamp to hold axle it is clamped last.
    1why the zip tie po was a ziptie specialist
    2 make correct by removing pin and sip tie. make sure castle nut is properly torqued and bolt in frame is torqued to spec.
    3 dont worry be happy . its all excess junk
