Rebuild carb xj turbo
Discussion in 'XJ Technical Chat' started by Rammstein86380, Dec 30, 2023.
  1. Rammstein86380
    Rammstein86380 Member
    France
    Hi
    I'am rebuilding the carb of xj turbo
    I have two questions:
    The 17,5 +-0,5mm for the float height is from the parting Line to the red mark or blue mark on the photo ?
    And how to adjust the pilot screw (how Many turn) ?
    Thanks a lot
  2. Fuller56
    Fuller56 Well-Known Member
    Blue line.
    Stand by for someone like @Simmy to report on the pilot screw.
  3. Simmy
    2-1/2 turns out
  4. Simmy
    What I do for initial float adjustment is to assemble the floats with the highest fuel level possible. Adjust so they close just before touching the body. I leave about 1mm visual clearance with the body.
    This is the highest fuel level possible without holding a float open.
    adjustments will all be one direction if any are required at all.
    Then the wet test.
  5. Rammstein86380
    France
    Thanks a lot carbs are ok with good float height.
    And i will manage the pilot screw with colortune
