Red loctite swingarm
Discussion in 'XJ Technical Chat' started by shovel268, Jan 19, 2017.
  1. shovel268
    shovel268 Member
    Edmonton Alberta Canada
    The safety washer that holds the bolt on the swingarm has broken is it safe to just use red loctite on the bolts instead
  2. jayrodoh
    jayrodoh YimYam
    Cleveland
    Personally I would just get a new lock washer, they're cheap and chacal will get you one within a few days. Using loctitie may affect your ability to torque to spec, although the torque spec is not as important on that side since it is the fixed pivot shaft side. If you do use loctite, I would leave the washer on as it may prevent the shaft from sticking out too far on the inside. Do not use any loctite on the adjustment side, you need to be able to torque that side properly to avoid damaged bearings.
  3. k-moe
    No.
    Same reasons as above, plus red requires 400 degrees of American heat to remove, and you'll burn the paint off of the frame when it's time to repack the bearings.
    hogfiddles and Jetfixer like this.
  4. Jetfixer
    Come on do you have an Ace hardware or a Lowes,Home Depot, Menards or any home center you should be able to come up with a lock washer don't attempt to rely on locktight alone and Kmoe is right about the heat ... Blue is better option , with new washer!!!!
  5. jayrodoh
    jayrodoh YimYam
    Cleveland
    It's more than a lock washer, stamped square piece with the sides bent down to fit over square "stub" on frame and two tab's to bend onto pivot bolt. Prevents it from loosening up and if for some reason it did loosen, it will prevent bolt from backing out. A standard lock washer can't do that.
    Lightcs1776 and k-moe like this.
  6. dkavanagh
    Rochester, NY
    It's more akin to safety wire. (vs lock washer)
  7. hogfiddles
    I wouldn't put threadlock on it
  8. shovel268
    shovel268 Member
    No problem I need a few things from Len anyway thank you
  9. Lightcs1776
    Lightcs1776 Active Member
    Upstate NY
    When I say things like that, I get dirty looks from my wife as she asks "what are you going to buy now?" Grin.
    Stumplifter likes this.
  10. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    Sounds like the intro for a firefighter themed male stripper.
  11. k-moe
    Shhhhhhh......go to pay the bills somehow.
    Toomanybikes likes this.
  12. shovel268
    shovel268 Member
    Bahaha don't have a wife anymore for that very reason
