Remote petcock
Discussion in 'XJ Modifications' started by motorheaddad, Dec 6, 2011.
  1. motorheaddad
    motorheaddad Member
    San Diego Ca.
    Looking for some ideas on how to do this mod or places where I can but a kit. Has anyone done this?
  2. SLKid
    SLKid Active Member
    Troy, Va (Charlottesville)
    Like.. Remote how?? Like wireless? Or located somewhere else on the bike. More info please!
  3. motorheaddad
    motorheaddad Member
    San Diego Ca.
    Mounted somewhere else
  4. parts
    parts Member
    prescott valley az
    You can buy a fuel valve from most hardware stores for
    lawn mowers, gen's etc.
    Just run a fuel line to where you want to hide the petcock
    being sure not to bind the line in rout to the carbs.
  5. motorheaddad
    motorheaddad Member
    San Diego Ca.
    But where do I find an adapter that bolts to the tank so I can run a fuel line? The reason I want to do this mod is that I swapped my tank and the petcock hits the carb. I want an adapter with a hose fitting that will bolt to the tank then I can mount the petcock remotely.
  6. bigfitz52
    How about swap the petcock with one that doesn't hit the carbs?
    The XJ1100s have a "remote" vacuum valve, but have petcocks on either side of the tank, only the valve itself is "remote." You would probably need to fabricate something.
  7. TIMEtoRIDE
    You use your current petcock set to "ON" or "PRI"
    That is, if it doesn't leak.
    temporarily, you could seal a leak with Yamabond.
  8. motorheaddad
    motorheaddad Member
    San Diego Ca.
    Bigfitz to the rescue...again!!! Thanks, gonna go searching for an XJ1100 petcock.
