Removing Atari, bike will not run
Discussion in 'XJ Modifications' started by BlkMage, Apr 12, 2011.
  1. BlkMage
    BlkMage Member
    Stead, NV
    I'm currently trying to remove my Atari and upgrade to Mikesxs gauges. I've got the headlight, brakelight, and taillight all bypassed, rewired for all of my indicator lights, and got the tach rewired. Now there is no power when I turn the key. No start, no lights, can't even get lights working with the key in PARK. Is there a magic wire that I haven't bypassed yet? I'm staring at the diagram in the Haynes but I can't find a major power wire that goes through the computer, only indicators that I'm not going to use (fuel, battery sensor, etc). As far as the two big plugs with 6 and 9 pins, I cut those off the main harness to make it easier to pick the few wires out that I wanted, so it would be tough to just plug it back in.
  2. Polock
    is anything going in/out if the ignition switch? just start following voltage and see where it gets lost.
    is the battery negative hooked to the frame ?
  3. BlkMage
    BlkMage Member
    Stead, NV
    Battery was never disconnected, should be fine back there. Bike ran great just minutes before unplugging the Atari. Guess I'll have to break out the multimeter and do some chasing. Battery to fuse, fuse to key, key back to fuses...
  4. BlkMage
    BlkMage Member
    Stead, NV
    DISREGARD! It seems I popped the 3-prong connector that runs to the key switch. Put it back together, lights right up! Unfortunately, now the bike doesn't want to start, I'm thinking the cool temperatures (46F) may be to blame.
    Gauges look great, thanks to some help from these forums the wiring seems spot on. Now just gotta get on the road.
  5. Carvall
    Carvall Member
    Seattle
    do you have pictures?
  6. BlkMage
    BlkMage Member
    Stead, NV
    Not yet. When I pull it out tomorrow I will take one. That way, I can brag about having an XJ with .2 miles on it!
    Stupid work tonight...
  7. Carvall
    Carvall Member
    Seattle
    LOL Im waiting for my vapor gauges. I will try to fit the vapor gauges in the old casing. Let see how it works out.
  8. BlkMage
    BlkMage Member
    Stead, NV
    The bikes had .2 miles on it! Or just new gauges...then again, only had 15,600 original miles before I pulled the Atari. However, tach suddenly quit working and my oil light stays on, even though it has plenty of fresh oil. Could the oil sensor be bad? Not liking the semi-syn oil? Maybe I tapped the wrong power? As for the tach, it doesn't "boot up" so it must be the main power line.
  9. Carvall
    Carvall Member
    Seattle
    Nice!
