Removing Carbs the Easy Way
Discussion in 'XJ DIY How-To Videos' started by Foofighter, Apr 11, 2016.
  1. Foofighter
    Foofighter New Member
    Canada
    Made a quick video showing how I got the carbs out of my girlfriends 1981 Yamaha Seca XJ750. I researched it beforehand and everyone made it sound like the end of the world, or at the very least you'd need to remove the air box. I managed to just slip the air boots from the carbs into the airbox to give enough room to slide the carbs right out. Hope this helps someone.
    Keeferheydude, Fix, Beck and 3 others like this.
    would have been better to see you actually remove the carbs.
    I remove the carbs the same way and use a dowel to push the sealing edge into the air box i heat them up with a hair drier and do 2 from each side of the bike
    some boots are overly stiff and need more heat than a hair drier can supply.
    Fix and Beck like this.
  3. Yardawg
    Yardawg Active Member
    Hatch NM
    I saw a thread somewhere on here a while back about using a ratchet strap to pull the carbs off. I tried it and it worked GREAT!!! Then I discovered that it worked just as great putting the carbs back on!
    Fleetwood and Beck like this.
  4. Scarbo
    Scarbo New Member
    Jackson, MS
    Yes. I was getting nowhere trying to pull the carbs back out on my '85 Maxim by hand. So I used two of my bike tie downs and the carbs just popped right out. Haven't tried putting them back in yet. Still working on cleaning them.
    Yardawg likes this.
  5. Andrew Nichols
    Andrew Nichols Active Member
    Minneapolis, MN
    Thanks for the hair dryer tip, I'm going to use that.
  6. VanNorman6
    VanNorman6 New Member
    Thanks for showing. It helped me get mine off. I did loosen the air box though and could push it 1./2 inch back giving me a bit more wiggle space.
  7. Jeremydh
    Jeremydh New Member
    New york
    Yeah just went through this whole process. Getting the carbs off wasn't too bad, for some reason. Getting them on was a snap using really long wood clamps. I simply tightened each side a little at a time. The REAL pleasure is getting the boots reconnected. I think the only way to do it is pushing them into the air box and then working them back out. The outer boots are the easiest. Boot number 3 (assuming right to left) is a bit difficult and boot number 2 is the hardest because the clutch cable is right in the way. I wish there was an easier way to reconnect them I just don't know what that could possibly be.
  8. k-moe
    Left to right, just like when reading.
    The airbox boots get easier to reconnect with practice.
  9. hogfiddles
    There is:
    1. Have some else do it
    Or
    2. Buy new intake boots and airboots from Len.
    Or
    3. Get a hairdryer or heat gun, and warm up the boots to soften them. A light smear of Vaseline on the intake boots will help the c arbs to pop right in. Then, I move the airbox back forward and tighten the bolts. From that point, I work the airboots back on, using a heat gun to keep them soft, a radiator hose tool, a brake hook, and one hand working from inside the airbox. It also helps to make sure that the front of the airbox has been warmed, straightened, and cooled down so that it is flat again, rather than concaved.
    kosel likes this.
  10. Franz
    I refitted my Carburetors today and it is quite easy once you get used to it, it was tricky the first time I did it but fine now.
  11. hogfiddles
    Usually takes only a few minutes.
  12. Franz
    Yes Hogfiddles at bit trickier than my old CB750K2 (which I sold years ago) but the XJ is a great bike and I am looking forward to getting it on the road now after the work I did on it. My father was a carpet loom mechanic and I used to watch him working on cars and bikes when I was a kid. It is great to fix things yourself and have a forum of other XJ owners to communicate with. My father taught me a lot about bikes.
  13. Dre42
    Dre42 Member
    Los Angeles, United States
    Also the airbox may have boots that are removable! I didnt notice that at first but the xj550 airbox has boots that come right off. You can remove them by gently rotating them and pushing them down to make way for the carb.
    It seems the company noticed this problem and started making air boxes that weren't as much of a pain to deal with when doing carb jobs...
  14. hogfiddles
    You just push them back into the airbox
  15. moperformance
    moperformance New Member
    It helped me! Thanks!
  16. Andrew Nichols
    Minneapolis, MN
    Easily (but CAREFULLY) remove the carbs from the intake boots with a ratchet strap on each side of the bike.
    dominicapavlova likes this.
  17. hogfiddles
    I just loosen the clamps, tip the rack up and down to pop them right out.
  18. aliyanage
    aliyanage New Member
    Switzerland
    Did it the exact same way but what would be interesting is to see how to put them back on the easiest way. Does anyone have a magic trick that makes it a bit easier to put them back on?
  19. XJ550H
    A little lubricant on the boots a little lubricant on the carbs start on the right side and just roll them right in I can do this with hard boots or soft boots
    Toyobaru866 likes this.
  20. aliyanage
    Switzerland
    thanks, worked like magic :-D
  21. jag3
    jag3 Member
    Daytona Beach, FL
    I've tried putting the cards back on and can't get them the fit all the way into the Iin take side. I put the aurbox side on and can't get the intake side to seat. Any help is greatly appreciated. I have tried for hours and I know it shouldn't be that hard.
    Thank you.
  22. hogfiddles
    Heatgun for softening boots on both sides, and a smear of Vaseline or engine oil for the intake boots. keep the airbox side boots dry. You want the stiction to help hold up them in place.
  23. santivelasco
    santivelasco New Member
    Spain. Cantabria
    For future problems of reinstalling the carburettors, (without hot) I add: put rubber bands 2 and 3, insert the carbs and adjust those two rubber bands. adding rubber bands 1 and 4 is very easy if you rotate them
  24. dominicapavlova
    dominicapavlova New Member
    Norfolk UK
    Rely helpful picture. Thanks. Justin
  25. Melnic
    Melnic Active Member
    If your using a ratchet strap, your not using the heat gun/hair dryer properly. hogfiddles has it right, heat and some lube.
    I don't push my intake boots in, I just heat up and pull out. I guess I could push in, but like to look them over.
    I've fiddled with my carb enough that I don't need any straps or dowels to do the job.
  26. hogfiddles
    You don’t need straps and ratchets to removecthe carburetors.
    1. loose airbox to carb boot clamps
    2. Push boots into airbox most of the way—theyre barely on the carbs to begin with.
    3. loosen airbox bolts and slide it back - only goes about 1cm anyway......
    4. Disconnect throttle and enricher cables, move clutch cable out of the clip.
    5. Loosen carb to manifold boot clamps
    6. Tilt carbs up and down while pulling to get them out of the boots
    7. Slide rack out to the side.
    to install: go in reverse order but a light smear of grease on manifold boots, and a heatgun will help the carbs pop right back in.
    DO NOT grease airbox boots.
  27. McTavish
    McTavish Active Member
    Daytona Beach, Fla.
    i used silcone spray
  28. hogfiddles
    Anything to lube the manifold boots. I just use a light smear of engine oil
  29. dominicapavlova
    Norfolk UK
    Can you get carb parts in the UK?
  30. hogfiddles
    Order from xj4ever.... i believe he ships to UK too.... I have no idea of the shipping cost though.
  31. Keeferheydude
    Keeferheydude Member
    Spruce Grove. Alberta Canada
    Nice job. You were patient and pragmatic. Pulling the carbs from their intakes can be different depending on how " Stuck " they are and the condition of the intake boots. I think this gentleman kept it short for that reason. A good start for the uniniciated.
    Yup I used a micro thin layer of synthetic grease, gently wiped that so it was barely noticeable. They went in with a minimum of resistance. Totally down with your method.
  32. CraigRegs
    CraigRegs New Member
    Des Moines, IA
    Always appreciate a good how-to vid. Thx
