removing hitachi bowl drain screws
Discussion in 'XJ Technical Chat' started by colinski6, Oct 19, 2015.
  1. colinski6
    colinski6 Member
    Gig Harbor WA
    Well I'm in a bit of a pickle. I have a 650 seca. The bowl drain screws are stripped off inside the bowls. I tried to drill them out but it has not really worked. Now I have some screws with big holes drilled in them stuck in the bowls. I'm sure there is a thread about this but maybe not one where an easy out hasn't worked.
    Colin
    use an easy out in the hole you drilled heat the bowl with propane torch a little.
    also soak from inside with penetrating oil.
    they are off the bike?
  3. Polock
    this might sound dumb but clean out the enrichment well first. get the carb cleaner to squirt through it now. reason being, you going to get it real hot and anything in the enrichment well might turn into a cinder and never come out.
    now do the penetrating oil thing, then with wood screws, screw it down tight on a board. pick the biggest ez-out that's going to grab and start it in. push and turn until it grabs, then take it out.
    now get the propane torch and heat it,hot, like it's going to melt hot (it won't melt) now put the ez-out back in and you should hit the same notches it made before and give it a twist. if it moves, stop take the ez-out out, let it cool a bit, more oil and twist again.
    i have 0 faith in ez-outs
  4. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
    Nothing like snapping an ez-out to make you cuss like a sailor.
  5. quebecois59
    I've been there, tabarnac !
    Stumplifter likes this.
  6. Stumplifter
    near Irma, WI
    LMAO :D
    I had to look that up, I'm gonna start using that one.
    Tabarnac!
    Alan63 likes this.
  7. quebecois59
    It is the sacred cabinet where the priest stores the sacred dishes. The right spelling is tabernacle, but it is less funny if you pronounce it too well...
  8. MN-Maxims
    MN-Maxims St. Paul Minnesota
    Saint Paul, MN
    Securing the bowls to piece of wood is the key to working in the drain screws. The threads are usually not whats stuck its the tip of the drain screw seized in the hole is where the problem is I have found.
  9. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    French has all the best religious swears. Most are untranslatable into english, or at least when you ask the Quebecer that you just cut off in Montreal traffic! Maudite! Signeur!
    quebecois59 likes this.
  10. Nuch
    Nuch Well-Known Member
    Suffolk County, NY
    I had more than one occasion where I used the GRABIT...
    http://www.lowes.com/pd_280440-41877-8520P___?productId=3030140
    Though in all honestly, I've had mixed results. For instance, BOTH of my master cylinder screws were frozen and stripped when I bought my 700. The first screw came right out. The second attempt... not so much. I ended up having to drill the hole out completely and dropping a long bolt through (nut on the outside of the MC) just to hold the cover on. It works, but it's not pretty. A new MC is not in the budget right now unfortunately.
    No doubt it was my nerves and lack of conviction that caused the failure in removing the frozen screw appropriately... I was worried that I was going to screw things up... Guess what? I did!
    Make sure you use the drilling side of the bit long enough to create a good solid hole for the "grabbing" side of the bit to do it's work...
  11. bunglejyme
    bunglejyme Member
    New Jersey
    Yes, heating them may help but be careful not to melt the aluminum. Aluminum doesn't give you and clue that it about to melt. It doesn't turn orange like steel, copper and brass when it gets to a certain temperature.
  12. bunglejyme
    bunglejyme Member
    New Jersey
    I used to work in Tool and Die and the worst thing was snapping off a tap in a block of tool steel that you spent days maching. We'd have to send it out to a shop that did EDM (electro-discharge machining) to "burn" the tap out.
  13. bunglejyme
    bunglejyme Member
    New Jersey
    When you finally do get the screws out, before you put them back in, lightly coat the threads and the tapered tip with anti-seize compound. Just a light coating.
    Also, don't over-tighten them.
  14. Polock
    your right, a propane torch will melt AL but the board will catch fire long before it does. if the board starts burning, that's a sign you got carried away :)
  15. colinski6
    colinski6 Member
    Gig Harbor WA
    Well I got them out with with a combination of EZ out, left handed drill bits, penetrating oil, and most importantly a torch. I got the screws that poke out beyond the bowl now so hopefully I won't have to do this again.
    Thanks to everyone for your help.
  16. XJ550H
    anti seize on the threads will ensure it does not happen again
  17. MN-Maxims
    Saint Paul, MN
    Or buy the Stainless Steel ones from Chacal and for sure it won't happen again.
  18. hogfiddles
    If they break off inside , you can also just buy replacement bowls-----/
  19. k-moe
    Stainless will seize in aluminum eventually (faster if you live near the ocean). https://www.fastenal.com/content/feds/pdf/Article - Corrosion.pdf
    Here is what keeps the drain screws from seizing; use them at least once a year.
