Removing links from chain
Discussion in 'XJ Technical Chat' started by loggerbomb, May 18, 2013.
  1. loggerbomb
    loggerbomb Member
    Ontario Canada
    Hi all! First time with dealing with reducing my chain and I am encountering a problem and would appreciate some guidance.
    I replaced my rear and drive sprocket and went to install new chain, problem is the one I was sold is too long even after seller told me it was correct length. So I got a chain breaker and tried removing a couple links. Problem is the pins are not coming out and the gizmo is spreading apart the plates. I had no issue on the old chain when trying it out. Is it a simple matter of grinding down the rivets on the new chain?
    Thanks to anyone who can lend some advice!
  2. bigfitz52
    Yep. File or grind away the "staked over" part.
  3. greg_in_london
    greg_in_london Member
    London
    Can you post a picture ? If I use mine correctly it will either push the pin out or not, but it can't spread the side plates when the chain is in place.
