Removing mufflers
Discussion in 'XJ Modifications' started by Rogan butler, Jun 7, 2017.
  1. Rogan butler
    Rogan butler New Member
    Victoria b.c.
    Can anyone help? Im trying to remove the mufflers from the h collector while everything is still on the bike. Have removed the clamp holding the muffler and h collector together..and removed the bolt holding by the rear footpeg. Ive been pulling and twisting and tryi g to get the mufflers off but no go...forgive me because im new but there has to be an easy way to get them off? Thanks in advance
  2. Polock
    they may have been put on in Japan. get some penetrating oil on them, support the weight so their not binding then try tapping on them someplace where you won't see a ding
  3. Wintersdark
    Wintersdark Well-Known Member
    Calgary, Alberta, Canada
    To get the stock mufflers off my parts bike, I had to get into the point where the attach to the collector (where the ring clamp is) with a screwdriver and pry the connecting end of the muffler open. It's got slots in it, which made the process pretty easy (relatively speaking) - they were the stock silencers, and unusably rusty... But I don't think they'd ever been off the bike. Was still a lot of work; there's a... Gasket? Kind of material in there, and it'd been reduced to a wired wire/carbon substance that did not want to let go.
  4. David Cormier
    David Cormier Active Member
    Calgary, AB
    I recently removed mine and like Wintersdark said, whats left of a gasket will come out in pieces, or whole if your lucky and look like frayed wire and rubber chunks. You can open up the tabs with the screwdriver and then bend them back in place once your new muffler or exhaust are in place. The diameter to fit inside the stock pipe opening I believe is 1 3/4" OD if I remember correctly.
    Wintersdark likes this.
  5. k-moe
    There is indeed a gasket there. Often times the gasket will rust to one (or both) mating surfaces. It's important to carefully remove all of the old gasket or the new gaskets will act like pipe expanders and make it darn near impossible to get the mufflers back on without causing damage.
  6. Rogan butler
    Victoria b.c.
    Sweet thanks...i got them off finally...they are pooched. I was wondering since i still have the h colllector on can i run the bike without the mufflers? It shouldnt hurt anything right?
  7. k-moe
    Your ears. Your body if the neighbors get annoyed enough. Otherwise no.
    hogfiddles likes this.
  8. Rogan butler
    Victoria b.c.
    I ride with my gf who has a harley sportster bored to a 1200 with vance and hines straight pipes ..i cant hear my bike even without the mufflers off if im within 5 meters of her
  9. k-moe
    Permanent hearing damage begins at 85 decibels. Keep that in mind.
    The damage is gradual. You probably won't even notice, until you begin asking people to speak up so you can hear them.
    Ketchup and hogfiddles like this.
  10. Wintersdark
    As a guy who's worked in manufacturing for decades (and even not particularly loud manufacturing), with a lovely collection of cards from twice annual hearing tests, I can attest to this. Also having owned a Ironhead sportster with 2" open straight pipes too.
    I never used to wear ear plugs, and you can see a gradual decline in the hearing test results over the years despite never feeling like I was losing hearing. I do now, of course, when I realized that while I don't feel at all "deaf", while everything sounds just as loud to me as it always did there are certain tones I just can't hear well anymore. This means while I can hear my wife and kids just fine, I struggle to make out some of what a buddy of mine says. Good times. There's a joke I'd make here, but I suppose it's best left unsaid :)
    But, I should be the last person to preach safety, as I don't practice nearly as much as I ought to. Still, it's worth saying: hearing damage happens WAY before sounds are so loud as to actually feel uncomfortable; it happens very gradually, and it is irreversible.
    k-moe and hogfiddles like this.
  11. hogfiddles
    The nurse at school says my selective hearing is just fine
    chacal, k-moe and Wintersdark like this.
  12. Timbox
    Timbox Well-Known Member
    I don't like the constant bells (ringing) but have to live with it now. So as far as pipes to, keep them, love to be quite and a "attentive head on a swivel" kind of rider then a "pipes save lives" ride. That is just me though. As for your bike I think the exhaust valves will suffer in the long run but k-moe would know more about that then me. Lack of back pressure and something to do with heat.
  13. hogfiddles
    These bikes are very free blowing, and there's virtually no back-pressure. Exhaust scavenging is primarily what we are dealing with
  14. k-moe
    I've been dealing with tinnitus since I was 15 (I forgot my hearing protection one day at the range. Dumb of me to shoot without them).
    Heavy machinery, firearms, rock concerts (and even loud exhausts at one point) have all contributed to hearing loss in the upper frequency range.
    My dad was a radio operator and machinist. He was more hard of hearing at my age than I am now, due in large part to my getting smart about my ears before they got too bad. I wear earplugs on every ride; even short rides in town.
    IF anyone needs more encouragement to keep a good set of mufflers on their ride, go price hearing aids (and find out that most insurance policies do not cover the cost).
  15. k-moe
    Eacactly. Free flowing, and quiet.
    It's been decades since a fella could get an increase in horsepower simply by pulling the mufflers off of an engine.
    Loud ≠ powerful.
  16. Wintersdark
    Heh it's funny, my hearing loss is almost entirely in the lower middle range - unusual, really, pretty strange. I'm fine with everything but typical male voices unless they're unusually deep. It's a really specific band I can't hear.
    What's bizarre is that it's almost unnoticeable to me. Everything is as loud as always but it's like certain guys just speak really quietly for no apparent reason - which is really annoying in otherwise noisy surroundings. Makes trying to have a couple drinks with the guys at a bar really frustrating.
    Ah well, it is what it is. Sadly, it's a lesson most of us only learn after the fact.
  17. cgutz
    cgutz Well-Known Member
    SE South Dakota
    Fireworks close to my ear in junior high gave me my tinnitus. The very loud college stereo in the 70's didn't help....
    I may be minority, but I like a smooth sounding, fairly quiet motorcycle.
  18. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    What?
    But seriously, if you still have the original Sportster pipes, they may slip on in place of the ones you've removed.
  19. cgutz
    SE South Dakota
    A man had 12 children.
    Someone asked him why he had 12 children.
    He replied, "Because my wife is hard of hearing."
    "What does hearing loss have to do with having children?" he was asked.
    He replied, "When we go to bed, I mumble 'do you want to go to sleep, or what' - and my wife replies "WHAT?"
    MattiThundrrr likes this.
