Replaced Handlebars, having issues
Discussion in 'XJ Technical Chat' started by Niteryder, Jul 10, 2015.
  1. Niteryder
    Niteryder New Member
    Fresno, CA
    I replaced the drag bars on my bike with a set of more upright bars. It was very straightforward, at least I thought so. After everything was reinstalled and I went to start the bike it revved very high. I took the tank back off and got the throttle cable where I thought it should be and restarted the bike. Idle came back down to normal for a minute then it kept wanting to die on me unless I kept it above 2k RPMs.
    Now it feels like it's not getting enough fuel but only at low RPMs, above 2000 RPM it feels fine. I'm assuming I pulled something loose when I took the tank off and put it back on. Bike ran perfect before I changed out the bars.
    All cables are long enough, it looks as though nothing was changed out when the drag bars were put on, so cable and wire length doesn't appear to be an issue.
    Suggestions on what to look for first?
  2. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    Start your bike, turn the handlebars full left then full right. If the idle goes up the cable may not be long enough or the adjustment is still off.
    Gary H.
  3. Niteryder
    Fresno, CA
    That was my first thought, but turning the bars did not affect idle after rerouting throttle cable. It feels like it is not getting enough spark or fuel at low RPM. It got too dark to see well enough, but from what I could see, nothing appears out of order. I'll have to check again tomorrow when I have enough light.
    I rode the bike for several miles after the swap, runs perfect until I stop and idle. It idles fine for a minute then starts to die. When I give it throttle it sputters and feels powerless until right around 2000 RPM, then clears up until I let it idle back down. Today before the swap ZERO issues, now, issues. I'm thinking I pulled something loose, pinched something maybe? Just curious what to look for first. The problem is this is going to drive me crazy until I can get to it tomorrow.
    One other thing I forgot to mention, when petcock is turned to on bike won't run at all, I gave to set it to prime to run. This was not the case before the handlebar swap.
  4. rocs82650
    Middle Tennessee
    The throttle cable and enrichment cable aren't swapped right? Stupid question... does your bike have enough gas to run in the "on" position? Have you tried the lever in the "reserve" position? If so the petcock diaphragm may be bad.
    Gary H.
  5. XJ550H
    measure your cables.
    check your vacuum line to be sure you hooked it up with out a kink you may try replacing the line you could have a hole it it from moving it if it is a stock hose.
    also check fuel line .
    check your clamps.
    look first at things you took off or disconnected
  6. XJ550H
    choke and throttle cable lengths.
    HCP2696 OEM original THROTTLE CABLE, with black curved plastic tube, adjuster nut, and thumb-wheel on the throttle end of the cable, for all XJ750 Seca models. Wire length = 40".
    $ 42.95
    HCP2655 Aftermarket THROTTLE CABLE, with bright plated curved metal tube, adjuster nut, and thumb-wheel on the throttle end of the cable, for all XJ750 Seca models. Wire length = 39-1/2".
    $ 32.95
    HCP17899 Aftermarket CHOKE CABLE, for all XJ750 Seca, XJ750 Euro, and XJ750 Police (24L and 37H) models. NOTE: experimental testing has shown that this cable is an excellent replacement cable to use on XJ550 Seca models if you substitute "euro" or "clubman" style handlebars for the stock handlebars. Wire length = 35-5/8".
    $ 18.95
  7. Niteryder
    Fresno, CA
    Tank is full, just filled up. I'll measure all cables and check fuel and vacuum lines later today.
    I'm thinking (hoping) it's just something I overlooked when putting everything back together.
