Replacing engine seals
Discussion in 'XJ Technical Chat' started by JCH, Oct 10, 2020.
  1. JCH
    JCH Active Member
    seattle wash
    My question is to replace the output shaft seal in front of the u-joint.
    Replace the seal behind the stator. Replace the seals behind the clutch and timing hub do you need to split the cases ?
  2. Franz
    No you can get the output shaft off the engine by taking out the four bolts. You might have to slacken off crankcase bolts near it a little and then retorque them up after refitting. There is the seal and a big O ring to be replaced.
    Keep your shims between the driveshaft and crankcase in the same location to control backlash in the bevel gears. I used cable ties to keep the shims in the original positions pictured on the driveshaft during my engine rebuild.
    Tabaka has a how to replace the seal behind the stator on here and he didn't split the cases. The seal behind the pick up coils has a lip so it is tricky to get it out. Chacal sells a replacement which has no lip and can be fitted without splitting the cases.
    https://xjbikes.com/forums/threads/...ith-pictures-applies-to-all-xj-models.108126/
    Which seal is behind the clutch?
  3. JCH
    JCH Active Member
    seattle wash
    Brain fog on the clutch seal LOL
    Sounds like none of them are practical to replace or recommend per service manual except maybe the stator seal.
  4. Franz
    Better leaving them if none are leaking. I only changed mine which were not leaking because l had split the cases.
    k-moe and JCH like this.
  5. Mezzmo
    Mezzmo Active Member
    With some hassle all the engine seals can be replaced without splitting the casing, not an easy job though. I wouldn't recommend it unless they are leaking as Franz mentioned. The seals that might be difficult to get out are the crank seals if they are original. Reason is stock cranks seals have a lip on the outer diameter that fits into the casing. The replacement seals don't have a lip so they can be refitted.
  6. k-moe
    No leaks, no replace.
  7. JCH
    JCH Active Member
    seattle wash
    Interesting... don't have any leaks to a drip , just noticed some light seepage from the driveshaft boot and the stator cover and then clean it up and doesn't seem to come back to any volume.
    Thank you all for your input.
  8. Franz
    Alternator one is replaceable. Driveshaft one depends on how much access you have. I had my engine out of the frame so was easier to get the driveshaft out of the case. Best to monitor them as you are doing.
