Richie Rich
Discussion in 'XJ Technical Chat' started by thehaig, Jul 13, 2008.
  1. thehaig
    thehaig New Member
    So.... y'all were right, the mechanic I hired to solve my richness problem failed, I've attached a picture of my carb, is the screw in the botton of the carb the fuel/air screw, if not can you tell me where it is. I was told this was neither a Mikuni or Hitachi carb, but rather a knock off installed by Yamaha. Are the mixture screws on this carb supposed to be set to 3 turns from the bottom like I've seen in other posts?
    Thanks!
  2. thehaig
    thehaig New Member
    Duh, here's the photo!
  3. bill
    bill Active Member
    Raleigh, NC
    picture here:
    http://www.xjbikes.com/Forums/viewtopic ... rt=15.html
    Also a lot of discussion in several threads. I would recommend reading as much of it as you can - I learned a lot doing so. Three turns is just a starting point.
    Search colortune and plug chop also do get your adjustments right.
    Good luck.
