rotor/desk
Discussion in 'XJ Technical Chat' started by ridz, May 18, 2007.
  1. ridz
    ridz Member
    Ride hard and live free!
    Im cleaning the rotors I call em disk wich ever you prefer..
    any hows I took some wet sanding paper (150) grit to them. they look decent enough but my question is : how much does the disc being true come into play? what I means is even all around the disc. I did this all by hand and I know im not that perfect. so should I post some pics so you can see. I dont think you would be able to tell from a photograph.
    But hey I love snapping off pics and posting them just ask rick :wink:
  2. MAX-X
    MAX-X Member
    Ohio
    I used a sanding block & basically knocked the glaze off. I started with 220 & went up to 600 for a nice smooth finish, If your using 150, I would just make sure your not leaving any gouges in the disk, nice and smoooooooth!
  3. MiCarl
    Unless your arm is mighty sore there is no way you sanded them out of true enough to matter (think Popeye).
  4. JimVonBaden
    JimVonBaden Member
    Woodbridge, Virginia
    Agreed!
    I used 150 wet/dry paper and sanded my rotors and disc pads and they bedded in beautifully!
    Not sure you need to go all the way to 600 grit.
    Jim :cool:
  5. ridz
    ridz Member
    Thats why Im asking my triceps are SWOLLEN..
    should I send some pics of my tris then :D .
    Thanx for the replys men.
  6. Captainkirk
    Captainkirk Member
    Northeast Illinois
    I'm still trying to figure out the tie between rotors and desks...... 8O
    To answer your ?, use a green RoLoc disc on your rotors (disks) and they will be restored to a serviceable (but not new) finish.
  7. ridz
    ridz Member
    typo captain sorry bout that..have scotty beam me up will you..I need some r&r :p
  8. Robert
    I've bedded my pads after a 150 grit clean-up no problem.
