Rotor holding tool
Discussion in 'XJ Technical Chat' started by Dantoys, Aug 1, 2018.
  1. Dantoys
    Dantoys New Member
    Williamsport, PA
    I do not have a Rotor holding tool... Saw a guy use a penny between the gears to stop them from rotating, can I use a penny on the final gear to stop the rotation and safely Torque my Rotor ?
    other suggestions are welcome.
  2. lostboy
    lostboy Well-Known Member
    Tillsonburg, Ontario, Canada
    If the engine is still in the frame you could put it in gear and have some one hold on the rear brake.
  3. Dantoys
    Dantoys New Member
    Williamsport, PA
    ok, maybe i will torque that in after the engine is mounted then. should be lighter to move as well, i'm getting to old for heavy lifting. lol
  4. Polock
    if it's in the bike, put a stick through the wheel, if it's on the bench a penny is better than your finger
    hogfiddles likes this.
  5. XJ550H
    flat bar stock bolted to ujoint mount when out of frame works too
  6. hogfiddles
    Stick through the wheel is my method...
