rubber restorer
Discussion in 'Hangout Lounge' started by FtUp, Feb 11, 2014.
  1. FtUp
    FtUp Well-Known Member
    pacific northwest
    I was just thinking about how much all the rubber parts to rebuild two sets of xj carbs cost and that the only rubber parts I didn't change were the slide diaphragms. has anyone used any kind of rubber restorer on the diaphragms? I am looking at these products specifically...
    http://www.ebay.com/itm/3M-39042-Rubber ... e9&vxp=mtr
    http://www.ebay.com/itm/Eastwood-Rubber ... 6c&vxp=mtr
    http://www.ebay.com/itm/Revive-Gel-Rubb ... 11&vxp=mtr
    http://www.ebay.com/itm/CleanTex-Rubber ... 3cdbb974f6
    CN
  2. adrian1
    adrian1 Active Member
    Sorry, I doubt you could bring them back from the dead as they have probably oxidised, not to mention the dreaded pinholes :(
  3. Bushy
    Bushy Active Member
  4. FtUp
    pacific northwest
    I am not trying to bring them back from the dead, just trying to lengthen their life span.
    CN
  5. lacucaracha
    lacucaracha Member
    Napa, CA
    I think straight up silicone is a good bet. The closer to 100% the better...
  6. RonWagner
    RonWagner Member
    Transmission fluid has some rubber restoring agents. I put a dried up rubber part in some fluid and checked on it in two weeks and nothing happened. I put it on a shelf and forgot about it. I stumbled on it a year laterr and the part was like new. I doubt you want to wait a year but if you have spare parts you could do it or maybe while the bike is stored for winter.
  7. Hamster
    Hamster Member
    NW WA
    Hey Noob, you got me thinking there with that list of 4. When I have a few lazy minutes I am going to search the MSDS for each of those and see where that points. My guess is, as already stated, silicone. But who knows?
  8. FtUp
    pacific northwest
    cool! I was hoping to get someone here who had actual experience, but any and all help researching this topic is welcome and much appreciated. I have many "irons in the fire" so to speak and have little time for research. cheers!
    CN
  9. Polock
    DOW 55
    DESCRIPTION
    Molykote®
    55 O-ring Grease is a
    silicone-based material that helps
    ensure positive lubrication and sealing
    by slightly swelling rubber O-rings
    and seals. This product is heat stable
    and oxidation resistant and is
    serviceable from approximately -65 to
    175°C (-85 to 347°F).
  10. Wirehairs
    Wirehairs Member
    St. Paul, MN
    x2 on the silicone. I use silicone spray on any rubber piece I remove, and let it sit in a can for a few hours before I put it back. It was my understanding that rubber hardens when it loses silicone, but I could be completely wrong on that account.
  11. Andyam6
    Andyam6 Member
    UK, Beds
    I used the wintergreen + xylene method on my airbox rubbers, the result was unbelievable, they went from bakelite to soft rubber in 24 hours, then another 24 hours to shrink back to size
    Removing/fitting the carbs is now almost a pleasure rather than pure, knuckle tearing torment
    I have a spare set of slides with stiff diaphragms, I reckon I'll give them a soak to see if it makes them usable again, they may come in useful some time
  12. quebecois59
    wintergreen and xylene? Is that something you mix yourself? How much of each? Where did you get the ingredients?
  13. Andyam6
    Andyam6 Member
    UK, Beds
    Sorry it's taken so long to reply, I've been in France visiting my Sister
    I can't remember where I got the recipe, it might have been on here or another moto forum, I've seen the formula in a few places
    I mixed the Wintergreen 30% to Xylene 70% in a glass jar and imersed the part in it. My carb boots I left in there for 24hrs, thinner section rubber would need less time
    I soaked my crispy old spare sliders for about 10 hours, two of them came out as good as new with lovely flexible membranes. The other two were wrecked, the rubber must have been very porous, as the membranes swelled they split the plastic retaining rings. Still, I got 2 usable spare sliders out of the experiment, they were headed for the trash anyhow
    I found the ingredients on Amazon here in the UK, they aren't too hard to find
  14. FtUp
    pacific northwest
    this reply inspired me to test my google fu again and I found that a lot of antique auto restorers like lestoil for restoring rubber. this is just one thread I found that talks about it.
    http://forums.aaca.org/f120/make-rubber ... 62022.html
    lestoil is a degreasing cleaner that can be found at home depot and most grocery stores.
    CN
