Rust removal
Discussion in 'Hangout Lounge' started by tabaka45, Aug 30, 2015.
  1. tabaka45
    tabaka45 Well-Known Member
    Brunswick, Georgia
    Anyone had any success removing rust from exhaust chrome? I have some pretty heavy rust on the chrome near the headers and on the rear of the pipes. I've used some 400 grit wet paper with chrome polish to remove the surface spots.
    Aluminum foil and cola.
    Stumplifter likes this.
  3. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
    ^ that really works. Crumple up the foil, use the cola (it worked with H2O for me) to moisten the foil and then start rubbing you exhaust. You will be amazed.
  4. Saltydog
    Saltydog Member
    Eastern NC
  5. tabaka45
    Brunswick, Georgia
    Thanks. I'll try the foil and cola tonight. Not sure I want to remove the exhaust to do the electrolysis, but it sure looks good.
  6. jayrodoh
    jayrodoh YimYam
    Cleveland
    Nice! What's your address? I'm gonna send you all my aluminum pieces for buffing :D
  7. Xythin
    Xythin Member
    Grants Pass, OR
    If you use diet cola it's supposed to be less sticky since there is no sugar. As a side note, it's still sticky..
  8. mtnbikecrazy55
    Evaporust is great.
