Saddle Bag Supports, looking for old Post
Discussion in 'XJ Modifications' started by JIMMYD, Apr 28, 2009.
  1. JIMMYD
    JIMMYD New Member
    A while back I was cruisin the forums and found where someone made saddle bag supports using 1/4" tube,brake line I think.I thought I had saved it but it's gone.Does anyone have this link in there files that you could give me? :?: Thanks,,,JIMMYD
  2. PainterD
    PainterD Active Member
    St. Cloud, Minnesota
    I made saddlebag supports out of 1/4" round stock. I came out from the frame where they're bolted, about 2 inches to clear the shocks. Then I made them come down the depth of the bags, out 90 degrees 4" for the bags to sit on (to keep from touching the exhaust when fully loaded) then back up to the rear mount.
    I just took a bunch of measurements, cut, heated and welded them together. It took me about an hour to make them. Then I just painted them black to protect them from rust. The bags are actually held onto the supports with thick wire ties. Now to remove the bags, I just unbolt the mounts and they come right off.
    Looking at them from the rear, they're shaped like this: l_
    l
    l
    l___
  3. tomandjerry00
    tomandjerry00 Member
    Washington DC/Philadelphia
    I like that idea a lot. Anyway you could post some pics? Thanks!
  4. PainterD
    Sorry, not able to get a photo right now (she has the camera today) but just an idea -
    I used 1/4" round stock for the braces. I attached (welded) a piece of 1/4" flat stock to the ends and drilled holes to bolt them to the frame rails on the bike (where there were bolts already) It took a bit of measuring and positioniing of the bags to get them just where I wanted them (to clear the shocks and mufflers on each side) If you have access to a welder, it's about as easy a project as you can get.
  5. SLKid
    SLKid Active Member
    Troy, Va (Charlottesville)
  6. PainterD
    Now there's a good idea for temporary applications. I leave my bags on all the time, but that's about the best idea I've seen so far if you want to remove the bags.
  7. SLKid
    SLKid Active Member
    Yeah pretty neat huh? Cheap, quick, easy, removeable. I'll have mine made by next week
