Screaming eagle slip ons
Discussion in 'XJ Modifications' started by Rogan butler, Jul 23, 2017.
  1. Rogan butler
    Rogan butler New Member
    Victoria b.c.
    Curious if anyone has tried these on their maxim? Does anyone know if they will fit? I was looking at the turn out version. I know i will probably need a new mounting bracket but will the opening fit on the 1 1/2" exhaust pipe? Im more just curious to see how they sound before i orderes them. Thanks in advance.
    Which HD are they for?
  3. Chitwood
    Chitwood Well-Known Member
    Fort Atkinson, Wisconsin
    I put some sportster mufflers on my maxim. I had to do a little customizing with them but nothing too serious.
  4. Rogan butler
    Victoria b.c.
    Im not sure. I think for a dyna? They are called screaming eagle turnout mufflers
  5. Rogan butler
    Victoria b.c.
  6. Rogan butler
    Victoria b.c.
    Sorry...what was the customizing you had to do? Did they just slip on the 1 1/2" exhaust pipe?
  7. Chitwood
    The point at which I cut what was left of the factory mufflers off didn't leave any pipe for them to slip on. I went to work and expanded some small sections of pipe that I welded in the factory pipe leaving me enough pipe to be able to clamp them on. I also had to cut and move the hangers as they weren't quite in the right position to line up with the factory brackets.
