Seafoam Question
Discussion in 'XJ Technical Chat' started by fyrman, Jun 16, 2006.
  1. fyrman
    fyrman Member
    Midland, Michigan
    OK, What is the proper mixture/procedure (or best) for cleaning out the carbs with Seafoam on my 1982 xj750????
    I have read sooo many threads here about it all somewhat diff.
    Thanx
  2. Robert
    I read (on the back of the can, funny how that works) you need 1 can for 8 to 14 gallons of fuel. Given we carry about 4 gallons on average, I settled for 1/2 can to a full tank of premium and ran it dry. Adjust accordingly for your capacity and you should be just fine. I don't think you'll hurt anything if you are a little generous with the juice.
  3. fyrman
    fyrman Member
    Midland, Michigan
    I put about 1/2 can for 1/2 tank, ran it for 10 mins now I'm letting it
    set overnight with with fuel on. Tommorow I'm gonna top it off with
    premium and run the piss out of it.
    I hope it does the trick.
    Thanx Robert
  4. Robert
    Sounds like a plan. Good idea letting it soak overnight.
  5. ctraugh2005
    ctraugh2005 Member
    Berwick, PA
    Ok, I may be a little new here, but what is this Seafoam you speak of. I dont think I have heard of it. Other in the ocian of corse.
  6. fyrman
    fyrman Member
    Midland, Michigan
  7. ctraugh2005
    ctraugh2005 Member
    Berwick, PA
    That stuff sounds pretty good, does it work good?
