Search Engine Ways
Discussion in 'Suggestion Box' started by HooNz, Sep 9, 2006.
  1. HooNz
    HooNz Member
    Well i'll have to retract my statement in a post via this forum where i typed the biggest idiot "on" these forums is the search engine...
    It is not a idiot! , its just Simple , we have something in common i summize.
    So , try searching say fer instance <cam chain timing> or <front fork seals> and see whats comes out its collection , Then search through Dumbo again with only <cam> or <fork> or even <seal>.
    If your reeding this your self oh great search engine can you think [if you do that is] about a different name for ones self , i would suggest "Result Motor" :wink: .
  2. Nick
    Nick Member
    Vernon, BC Canada
    Hey HooNz, ( using your example ) if you search for <front for seals> you will come up with 654 possibilities.
    If you change your search to <front and fork and seals> you will come up with only 44 possibilities.
    Dunno if you knew this, thought I would throw it by you!
