Seca 750 drain screw dimensions
Discussion in 'XJ Technical Chat' started by ryanismyname, Jan 11, 2010.
  1. ryanismyname
    ryanismyname Member
    Baltimore, MD
    I'm going to adjust the floats the "right" way this weekend. I used trial and error this weekend (don't have a vise/clamp to hold the carbs level) and I thin k they're a little lean now. I know the drain screws are going to most likely be destroyed during removal so can someone give me the dimensions so I can get them before then?
  2. Polock
    6X1X long enough
  3. iwingameover
    iwingameover Active Member
    Carb drain screws? They're not normal screws. I've got an extra rack that should have some servicable drain screws in them if you need.
  4. Polock
    teflon tape takes care of the special pointy end or i think chacal sells ss socket head pretty ones
