Seca with issue
Discussion in 'XJ Technical Chat' started by WesleyJN1975, Mar 20, 2011.
  1. WesleyJN1975
    WesleyJN1975 Member
    Bellmawr, NJ, USA
  2. bigfitz52
    Sounds to me like a holed piston and you're hearing blowback though the crankcase breather which is cast into the clutch housing. Or a broken/stuck valve. Doesn't really sound mechanical so much as it does like air moving rapidly through a hole. First step would be a compression test, then go from there.
