second check my valves?
Discussion in 'XJ Technical Chat' started by som1somwhere, Apr 7, 2014.
  1. som1somwhere
    som1somwhere Member
    United States, Illinois
    ok so first time ever doing valves.i did all of them and id like a second check and where to get ahold of shims.
    CYL:------1----------2----------3----------4
    IN:------.13--------.08--------.08--------.13
    OUT:--.15-.18---.10-.13---.15-.18------.15
    shim
    IN:------------------285-------280------------
    OUT:----275-------280-------280--------280
    replace
    IN:------------------280-------275-----------
    OUT:----270--------270-------275-------275
    am i correct? and should i even worry about the .15's on the outs and i should say that the .15-.18 means it fits my .15 but not my .18 same with the .10-.13. my shim tool goes by .02 increments
    bike specifies INS being .11-.15 and OUTS at .16-.20
  2. bensalf
    bensalf Well-Known Member
    yorkshire ,england
    if your valve clearances are too tight, then you need thinner shims not thicker ones
    stu
  3. som1somwhere
    som1somwhere Member
    those numbers are based off the chart. matched up my measured clearance and shim number. AH NEVERMIND i see what i did wrong imma correct it now. i was wondering what those top numbers were for
  4. KrS14
    KrS14 Active Member
    St Marys, Ontario
    I'd say you need a better reading for those exhaust measures. Is it .15 or .18, makes a big difference on whether you're changing them or not.
    0.18 leave it be. 0.15 = one size less.
  5. bigfitz52
    You need a more accurate set of metric feeler gauges to begin with.
    K-D Tools' pn 2274 is widely available.
  6. som1somwhere
    som1somwhere Member
    well with my set they were from oreillys so.. idk i may just rip them apart and put 2 together to get the number i need. and to KrS14 it will fit a .15 in it but not the .18 so it could be a .16 or.17. ill figure something out. been sick so going out there in the cold is a bleh
