Seen this thing anyone?
Discussion in 'XJ Technical Chat' started by HooNz, Jun 20, 2006.
  1. HooNz
    HooNz Member
    The motor slowly getting back together , when i first pulled the LH side cover this steel thing fell out of the space between the cover and crankcase , anyone know where or what it is/does , i think its from above [carbys] area . anyone?......
  2. FinnogAngela
    FinnogAngela Member
    Copenhagen, Denmark
    Could it be the fuelhose holder (with the tip broken off)? (Will try to find a pic later).
  3. Hired_Goon
    Hired_Goon Member
    Oz
    That's a spare bit, we've all got them :wink:
    Seriously, How thick is it. Looks like a cable holding tab thet's been stretched out. Did it come from inside the cover or just jammed in somewhere? LH side cover is ignition components so wouldn't want someting missing in there. :?
  4. Knick
    Knick Member
    austin,tx
    Looks like the tab that pushes the crank case trigger wires back under the tranny/engine gase.
    It should go over the lower left allen bolt as you are looking at the shifter.
    It keeps the wires from getting dorked up by the shifter end..
    or in my case it tried, but the shifter ended up hammering on them anyway..
  5. geebake
    geebake Member
    Audubon, NJ
    Oddly enough. I was looking at an identical part last night and scratching my head. On my Turbo Seca, there is an identical looking part that is held on with the llower left bolt that holds the rear cover on. It hold a line in place, though not very effectively.
    Greg
  6. bpberk62
    bpberk62 Member
    <a href="http://maps.google.com/maps?q=47.989922+-
    Sometimes I go to Bike Bandit .com and search thru their OEM schematics. It may take a while to look because you have to keep flipping back and forth but it's at least a source.
    Unfortunately, it won't help at all if it's a part of something that broke off.
    Good Luck,
    Bob
    '82 XJ550
  7. BlueMaxim
    BlueMaxim Active Member
    Central Mississippi
    I think Knick is right. Looks just like the one I had to put back i place when I changed my oil level sending switch.
  8. Robert
    Looks like the keeper that holds my wires in place in that area.
  9. HooNz
    HooNz Member
    ok , thanks fer the feedback that sounds ok by me [wire holder thingymabob] , and it was just jammed in floating about.
    at least i know now with the help of the forum its a thing to look at when the motor is back in...ta
  10. jdrich48
    jdrich48 Member
    Smithfield, North Carolina
    Here's a pic that might help.
  11. Robert
    Would help? Rich, you underestimate the value of your picture. Your shutter has captured more than any words we could write!!!
