shaft drive noise
Discussion in 'XJ Technical Chat' started by jcboyd, Oct 1, 2009.
  1. jcboyd
    jcboyd Member
    Dickinson, Texas
    how much noise should the shaft drive make on a 1983 xj 750
  2. mlew
    mlew Well-Known Member
    Apex, NC
    none, you should not be able to hear it when riding.
  3. SQLGuy
    SQLGuy Well-Known Member
    but the middle gear whistles/whines pretty loudly
  4. mlew
    Apex, NC
    Even the middle gear should be quiet, I would be concerned if I could hear it riding down the road.
  5. SQLGuy
    We must have a lot of concerned XJ750's riders here, then, because a lot of people talk about their middle gear "whistle" as being quite noticeable (and normal). Mine certainly is noticeable.
  6. TIMEtoRIDE
  7. SQLGuy
    Does this situation exist on any of the chain drive bikes, though? I had though it was only the shaft drive ones that exhibit it. Is it only the shaft drive models that don't use a primary chain?
  8. stereomind
    stereomind Active Member
    Tulsa, OK
    The 550's have a primary chain, so they don't whine... they have their own unique rattle at idle, though. Scared the hell out of me till Fitz explained it.
    The crank to basket gears on the 650s and the 750s are cut straight.... Straight gears are noisy. Hypoid gears are quiet, but are a lot less forgiving, and require special lube.
  9. MiCarl
    The primary drive (the link between the crankshaft and transmission) on many Yamahas is a straight cut gearset. These gears make a whistle noise that is similar to thousands of crickets chirping and it is entirely normal. The RPM and volume tends to vary from motorcycle to motorcycle.
    The XJ550 uses a chain primary drive. No crickets.
    Noise in the shaft drive is either clunks (universal joint) or a moaning sound (bearings). These sounds are not normal and indicate wear/failure.
  10. jcboyd
    jcboyd Member
    Dickinson, Texas
    actually I only hear it when I am coasting and the bike is off
  11. adrian1
    adrian1 Active Member
    8O But I thought your petrol over there was cheap :lol:
  12. jcboyd
    jcboyd Member
    Dickinson, Texas
    haha. good come back.
  13. TIMEtoRIDE
    When coasting in neutral, you have 2 bevel gear sets, ten straight cut gears meshed and spinning, and at least seven bearings, and a speedo cable. Maybe more bearings.
    I hope that narrows it down- - :p
    Do you hear a whine or a rumble? Rumble is bad.
  14. bigfitz52
    "Doctor, it only hurts when I go like this."
    "Don't go like that."
    That being the case, how in the heck did you DISCOVER this?
