Shield under XJ550 carb rack necessary?
Discussion in 'XJ Technical Chat' started by Icantinaturner, May 12, 2009.
  1. Icantinaturner
    Icantinaturner Member
    nr Gettysburg, PA
    I've seen pictures of XJ550 racks and there appears to be a shield beneath the carbs. What is its purpose and is it critical? The pitiful bike I've just bought doesn't have one and seems to run alright.
  2. stereomind
    stereomind Active Member
    Tulsa, OK
    I think it's a heat shield. It would keep the gas in the bowls from boiling when the engine is hot.
    Just a theory....
  3. 86xj700_indy
    86xj700_indy Member
    thats all it is. it does not need to be there for you to get maximum performance
  4. Icantinaturner
    nr Gettysburg, PA
    Thanks, Stereo.
    I like your theory and that's kinda what I thought initially. The cooling airflow at the rear of the cylinders would seem to be more restricted and warmer. I do wonder why other bikes can have the carbs in the identical postion and not be troubled by heat. I've had a GS 1000 and GPZ750 without those shields. :?
  5. Icantinaturner
    nr Gettysburg, PA
    Thanks Indy.
  6. bigfitz52
    The shield is only on the Seca 550, not the Max. I'm not sure WHY, it's oriented wrong to be much of a "heat" shield. It looks more like a "carb drip pan" to me; maybe Yamaha was worried that with the more sporting orientation of the Seca, it would cause fuel to somehow escape the carbs?
    I honestly don't know why it's there.
  7. bill
    bill Active Member
    Raleigh, NC
    Maybe it's to add to the sportier look :lol: Like spoilers on an acura - they always crack me up...
  8. bigfitz52
    or keep you from getting to the float bowls without pulling the whole bloody rack...
  9. Icantinaturner
    nr Gettysburg, PA
    Thanks guys. I guess I can stop losing sleep over the absence of the shield, right? :D
  10. bill
    bill Active Member
    Raleigh, NC
    There are many more things to lose sleep over ...
