Shifting Prob.
Discussion in 'XJ Technical Chat' started by DarthMactis, May 21, 2007.
  1. DarthMactis
    DarthMactis Member
    my 83 xj750 seca has a shifting prob. when i go from second to third and up most of the time it just acts like its in nutral and some time it catches. anyone have any idea what it could be?
  2. DarthMactis
    DarthMactis Member
    also the clutch lever is really really hard to pull. its not the cable i check that cant find anything else that it could be.
  3. DMoreyXJ550
    DMoreyXJ550 Member
    Columbus, Ohio
    My Maxim has had something like that happen. Ill be in a gear and I'll lay on the gas to pick up speed and it kinda acks/feels/sounds like the tranny is slippin....Is it normal? I doubt it but ya never know with a bike that is 25 years old.
    Good topic dude, I can relate.
    Derek
  4. KiwiXJ750D
    KiwiXJ750D Member
    New Zealand
    So your revs increase but your speed does not increase. It's not normal for the clutch to slip (it's not a auto!).
    Check:
    Oil change.
    Clutch correctly adjusted, not binding and the lever/cable pivots are free and (on the hand leaver) greased..
    Then:
    Clutch plates and springs, the clutch shaft bearings are not binding.
    Clutch plates and springs are easy to check, if on the sidestand oil does not need to be drained , a new clutch cover gasket made, plates checked for spec and signs of wear, just remember to use a torque wrench on reassembily of the clutch.
