Shim pool / shim bank
Discussion in 'XJ Technical Chat' started by kudoskun, Jun 27, 2012.
  1. kudoskun
    kudoskun Member
    Minneapolis MN
    Does anyone have the following size shims:
    260
    265 (x2)
    275
    295
    I've contacted Hogfiddles, but haven't heard anything back. I'd like to get the moto buttoned up and running again and need to trade for some shims!
  2. JPaganel
    JPaganel Well-Known Member
    Minneapolis
    I need 265 myself. However, I should have an extra 275 when I'm done. I pmd Hogfiddles, too, he said he'd take a look, but I haven't heard anything else. Maybe he's busy.
  3. kudoskun
    kudoskun Member
    Minneapolis MN
    JP, you should have your bike up on the stand next to Wirehairs' and my own.
    Seems we all decided to do it at the same time :D
  4. JPaganel
    Minneapolis
    Well, it's up on the stand. :D
    I just called Hitching Post in Fridley. They can get shims in 3 days and they charge $22.50 per shim. Kinda pricey, so it wouldn't be my first choice.
    I need four 265 shims and one 270. I will have 275 and 280 shims left over.
  5. kudoskun
    kudoskun Member
    Minneapolis MN
    Well, Chacal has them for about $10 a piece. We can order a "shim refill kit" with 5 shims of each "step" in a particular range from bikebandit. Problem is those refill kits cost ~ $36, and the ranges they cater to are in .25mm increments. so one kit is 2.4-2.65mm, then they go up and down through the ranges in that .25mm increment per kit.
    You'd get 5 shims of each size for the listed range. I need shims from 2 kits, so the cost of $72 is a bit high for me. I'd be set for shims, but I don't think I'd want to run my own shim pool.
    The link for the kit: http://www.bikebandit.com/hot-cams-valv ... d?m=147101
  6. moellear
    moellear Member
    Lima, Ohio
    If you hold your pants, Hogfiddles will get back with you. I personally talked to him late this past weekend & he is away; busy the entire week (hence why you don't see him on here either). I highly recommend getting shims from hogfiddles especially if you are interested in NOS shims. He offers a great deal with trading your old shims & some extra $ for NOS shims.
  7. Wirehairs
    Wirehairs Member
    St. Paul, MN
    We need to all make a beer run together when we finally get this done. Ugh!
  8. JPaganel
    Minneapolis
    Last night I found I'm a little further form that. See my brake thread...
  9. Sabre
    Sabre Member
    Lansing, MI
    Chacal has shims for $9 and change a piece. Priority mail will be to you in 2-3 days. I've ordered a number of parts from him and have always found his communication excellent, his service top-notch, and his shipping quick.
    Why look anywhere else, especially for double the price???
  10. fuggers
    fuggers Member
    I just did a swap with Hogfiddles and it was great. Such an amazing service he has. Ended up saving me a lot of money. Kudos to him.
  11. maximike
    maximike Member
    Portland, OR, USA
    This is my next job, I'll put up what I have/need in the next couple days. Unless I get too wrapped up in brake caliper rebuilding.
  12. Wirehairs
    Wirehairs Member
    St. Paul, MN
    Well, if the 3 of us want to go in, I'm willing to do it. We can sell/trade the leftovers just to enough to break-even.
  13. tabaka45
    tabaka45 Well-Known Member
    Brunswick, Georgia
    I have 2 265's. could use 260's and 250's
  14. hogfiddles
    I just emailed all of you who had sent me emails.....I have been away working at Boys' State for the week and only got sporadic chances to try and check emails. the campus wireless there was difficult, too.
    So....I ba-a-a-a-a-a-ck :)
    thanks for your patience......I'm sure it was starting to wear thin, and I apologize for that. Communication things were a bit out of my control this time :(
    Dave Fox
  15. hogfiddles
    Hey Aaron, was hoping to hear some good news from you.......everything working right now?
    Dave F
