Shrinking Throttle Cable
Discussion in 'XJ Technical Chat' started by ThatNaysayer, Jul 26, 2011.
  1. ThatNaysayer
    ThatNaysayer New Member
    Chicago
    So I am reinstalling my carbs the other night and halfway through I notice that the throttle cable looks oddly short, so I go ahead at attach it and voila it is in fact a few inches too short. I have not touched the throttle cable and I haven't even the slightest idea as to what could cause these few lost inches.
    I removed the cable and checked for kinks and such, nothing, the cable almost literally shrunk. Either that or something on my carbs is different, and I hope that is not the case since that means I gotta take em apart again. Any ideas on what this could be? Do I need to get a new throttle cable?
  2. RickCoMatic
    No.
    Look around for the CHOKE Cable.
    Make sure you got the right one going to the Carbs.
  3. lostboy
    lostboy Well-Known Member
    Tillsonburg, Ontario, Canada
    There is a short cable about 2 inches long the goes at the end of the throttle cable. This short cable goes on a cable guide on the carb and has a connecting link to the throttle cable. Look around the center of the carb. It proberly has fallen down.
  4. ThatNaysayer
    Chicago
    lostboy, thank you! I had completely forgotten that cable even existed! I am going to see if I can find it, on the off chance that I cannot is it something that could be made? Or something I need to order from Chacal?
  5. bigfitz52
  6. lostboy
    When I remove the carbs I use a small zip tie to hold the small cable to the guide. I think the whole world would fall apart without zip ties.
  7. ThatNaysayer
    Chicago
    Managed to find it! Sadly I found it an hour after I ordered a new one from Chacal. Carbs are back on and everything is running. Thanks again!
