Signals
Discussion in 'XJ Technical Chat' started by MACDBF, May 6, 2008.
  1. MACDBF
    MACDBF Member
    Halifax, NS. Canada
    Ok guys, I know this topic has been beat to death already, but I have a problem that I can't fix. My turn signals work just fine execpt they won't turn off after the switch zeros. I've tken it apart, clean the contactors and even sprayed a litle WD40 in it to loosen things up.
    But to no evail... any suggestions
    Cheers Mac
    I will get this thing on the road soon....RIGHT?
  2. ZaGhost
    ZaGhost Member
    Dartmouth, Nova Scotia
    You're pushing down to cancel right?
  3. Gene
    Gene Member
    Madrid, Spain
    I believe some maxims have two cables for each turn signal, some others only one. Are your turn signals stock?
    I replaced one of mine with a two wire model and had that issue. Had to add ground to the light bulb casing.
