Simplified wiring harness?
Discussion in 'XJ Modifications' started by jrust88, Dec 28, 2011.
  1. jrust88
    jrust88 New Member
    cochran, ga
    I am rapping up a project 81 650 and I realize that the previous owner before me decided to do a hack job on the wiring. So, I looked at repairing it but I think it would just be best to get a whole new harness. Any suggestions on how to go about this?
  2. tskaz
    tskaz Active Member
    Saint Louis, Michigan
    One of the members here has a schematic for a simplified wiring harness, but I can't remember who.
    Do a forum search for "simplified basic wiring harness"
    Shouldn't be too long before you find it.
  3. tskaz
    tskaz Active Member
    Found it.
    dwcopple's wiring diagram:
    Corvair1 likes this.
  4. jrust88
    jrust88 New Member
    cochran, ga
    thanks alot, this should do the trick
  5. FJ111200
    FJ111200 Active Member
    Crewe, Cheshire, England
    I've been trying to wire in an XJ1100 ignition system to one of my XS1100's, but i'm having trouble wiring in the Boost sensor, which is the same item as on the XJ650 Turbo.
    Looking at that diagram above and also when using the search button, it shows no sign of the boost sensor.
    So is it possible to leave it out? Sorry that's a bit mis-leading, i've already left it out on my XS but find it a struggle to get from 75mph to 90, and then virtually impossible to go over a ton, without using the boost unit.
    So an electronics expert mate of mine on the XS forum told me how to wire it all in but i don't get a spark at the plug, but all the other electrics work.
    The XJ11 10M TCI is a plug and play of sorts with the XJ pick up coils in place of the stock XS items.
    So where am i going wrong and is there an actual way to do it or should i just forget it?
  6. darkfibre
    darkfibre Member
    Perth, Australia
    The boost unit is just a vacuum sensor and is used for changing the advance curve.
    If you were going to leave it off, to get normal full throttle power you will need to substitute a signal that simulates full load.
    Looking at the manual you would need to use around a 2 volt signal.
    Your electronics friend may be able to make up a voltage divider circuit to achieve that.
  7. FJ111200
    Thanks.
    Will look into it.
  8. kevin1000
    kevin1000 New Member
    Denver,CO
    So then, if I'm looking at this right, it is possible to separate the other three circuits from the main circuit without any detrimental effects? Thereby allowing me to use a lower amperage fuse than 30 for the main circuit?
  9. Pennywise
    Pennywise New Member
    Elizabethtown, Kentucky
    Thank you for adding that diagram! I had copied the original wiring from the Service manual and I was going through making changes to try to limit what is needed.
    I am back in the spirit of working on my XJ750,
    (I had it given to me back in 2010, I was able to get it running during the summer but I did not have time to take a motorcycle class so i just let it sit over the winter in the shop.
    When i tried to start it during spring 2011 it wouldn't start, i spent about a month rebuilding the carbs replacing everything and I just couldn't get it to run so i pushed it into the corner and left it. )
    I took a Rider safety course the middle of last year and acquired my license, Once i had my license I went and purchased a 2008 Kawasaki Vulcan900 at my local dealership and I have been riding that as much as i can since.
    That bike re-kindled my passion for motorcycles.
    Now i have plans to slim down my XJ to the bare bones and get it running again. This forum will give me a great start on getting the wiring worked out.
  10. streetbrawler750
    streetbrawler750 Member
    Minnesota
    Yes the main fuse is seperate, run a hot from on side of the key to feed, say the left side of the fuses, then the right side of the fuse goes to what ever you are powering
  11. Richard Radcliff
    Richard Radcliff New Member
    Hobbs New Mexico
    I have recently bought my first motorcycle. I bought a 1985 Yamaha Maxim x. That is all I know about it. How do I figure out everything I can about this bike and possibly get my hands on a owners manual and a repair manual. Thanks in advance.
  12. hogfiddles
    First---Read every single post in every single forum on this whole site.
    Or, at least read through " the Information Overload Hour".
    Welcome aboard.
    If this is your first bike, be CAREFUL---- you're starting off with a HOT ROD!!!
  13. k-moe
    Even by modern standards it's a hot rod.
    The X is a machine that will overwhelm a new rider quite easily.
    Have you taken a rider's safety course?
    hogfiddles likes this.
  14. hogfiddles
    Yup... You got a bike that has about 86hp, and has been known to do 0-60 in about 3 seconds, and had 1/4 mi times of about 11.5 seconds at about 115mph
  15. jwrphil1992
    jwrphil1992 New Member
    Florida
    I have an 1982 XJ 1100. Where would I wire the boost sensor into this?
  16. k-moe
    An XJ1100 is really a restyled XS1100. The wiring is quite a bit different, and this minimal wiring diagram really isn't suitable for it.
  17. jwrphil1992
    Florida
    Okay, Thank you! Is there any wiring diagrams for the XJ1100 available? The wiring harness on mine is melted pretty bad. It runs but it needs wiring work done before it causes any major problems.
  18. k-moe
    xs11.com
  19. sknight
    sknight Member
    BC. Canada
    So guys, Gals
    I have a 81 xj650, I have the wiring mostly figured out... added LED signals.
    All seemed to be going good till I started it.
    The Diode (in headlamp) got hot and melted. On the simplified wiring diagram they dont show one.
    My question is.... Is this a need componant or or can i leave it out?
    BTW my wiring is pretty much stock
  20. XJ550H
    the diode block is used with the oil level switch and the head light relay
    you can make a diode resistor set up for the oil light , and bypass the head light relay using a switch as shown in the min wiring diagram
    or make your own diode block
    upload_2017-1-28_9-41-33.png 650h diode block
