Snapping exhaust bolts
Discussion in 'XJ Technical Chat' started by 82madmax, Apr 21, 2016.
Tags:
  1. 82madmax
    82madmax New Member
    SFSD
    i ran into an issue with the 4-1 header snapping the exhaust bolts on cylinder 1. I thought maybe because of the 1100 being in a 750 frame the torque is snapping them off so I switched to a 2-1 header and still having the same issue. I'm afraid to drill out the bolts risking putting a hole in the head. Any ideas what I can do to stop the exhaust leak in cylinder 1?
    you can use alum mixed with water make a bowl it will dissolve the steel not the aluminium . there is a video about it.
    what torque spec are you using to tighten the nuts to ?
  3. jmilliken
    jmilliken Well-Known Member
    Dillsburg, PA
    Disolve it as mentioned above, or take it to a reputable machine shop.
  4. 82madmax
    82madmax New Member
    SFSD
    I haven't spec'd torque the header is snapping the bolts clean off
  5. k-moe
    Loosen the entire exhaust system. When you tighten it all back up, start at the headers (once the studs are repaired). The only way to eliminate the exhaust leak is to replace the broken studs.
    What is this about an 1100 engine in a 750 frame? What engine is the exhaust meant to be for?
  6. mlew
    mlew Well-Known Member
    Apex, NC
    I want to know about this 1100 engine in a 750 frame also. We need to see pics .
  7. 82madmax
    82madmax New Member
    SFSD
    Here are pics
  8. 82madmax
    82madmax New Member
    SFSD
  9. XJ550H
    did you have to change the swingarm , drive shaft. a few more details
    donuts
  10. k-moe
    That's not an XJ 1100 engine.
    This is
  11. k-moe
    Did the exhaust come off of an 1100 maybe? That would cause things to not line up correctly and could snap off the exhaust studs.
  12. Polock
    Once the pipe is in the head, it pretty much can't move side to side. The only thing left to snap the studs is moving out away from the head and there is nothing doing that unless the mount under the engine is on a big time bind.
  13. 82madmax
    82madmax New Member
    SFSD
    First I bought it with the motor in it. I did not research any part numbers to see if what the guy I bought it from was correct when he said it was a 1100. The original exhaust that I had a problem with was 4-1 single pipe off the left side. The pipes I now have on it are 2-1.
  14. XJ550H
    the short vin on motor can help ID motor, plus between cylinders 2&3 near exhaust ports will have size of motor
