so the ignition switch is good, now what
Discussion in 'XJ Technical Chat' started by yamaman, Jun 19, 2009.
  1. yamaman
    yamaman Member
    Staten Island, NY
    motor was in a hydrolock and I pushed the starter button a few times to try to force the start instead of pulling a plug like im supposed to and the ignition light stopped coming on and I stopped hearing a relay click, but I had a flaky keyswitch so I reassembled it and had good continuity with the meter. plugged it back in with a buddy holding the headlight attached, good batt voltage, good battery connections, all fuses tone out.
    so what's next down the line? figures cause im in the middle of tuning. thanks ya'll
  2. yamaman
    yamaman Member
    Staten Island, NY
    bumparooski
  3. helmet
    helmet Member
    On 2 wheels... just lost my hat.
    can you jump the relay with a screwdriver and get it turn over?
    mine did the same thing.
  4. yamaman
    yamaman Member
    Staten Island, NY
    which relay, where? did your console green ingition light not come on like mine?
  5. tennsouthernbelle
    tennsouthernbelle Member
    Morristown, TN
    Jump the starter and see if it works.
  6. yamaman
    yamaman Member
    Staten Island, NY
    traced the wiring diagram and ended up finding the Starter Switch was bad which is connected directly to battery via the metal bus bar. when the switch was touched or moved the ignition lights would come right on, when the starter button was pushed, either the engine would turn over or the switch would vibrate and fail.
    I'm really surprised I never read a thread with this switch mentioned Ever!
