Something weird with cylinders
Discussion in 'XJ Technical Chat' started by dustball, Jun 12, 2008.
  1. dustball
    dustball Member
    Oak Harbor, WA
    Problem is 2 and 3.... wouldn't fire.. so i switched out the spark plugs... no avail.. then i switched out the coils... ran fine for about 100 miles... 2 and 3 wouldn't fire... swithced out the cdi... and coils again.. ran fine for 100 miles.. now 2 and 3 won't fire... carbs are cleaned.. ohmed out everything... good..
  2. wizard
    have you cleaned the earth wires to the coils?
  3. Robert
    You may also want to check your wiring from the pick-up coils to the TCI and from there to the ignition coils. You should also open up your TCI and check the circuit runs. They can and do crack. Repair any discrepancies you find. If you are not sure how to do this, let us know.
  4. dustball
    dustball Member
    Oak Harbor, WA
    thx.. I just had this problem before and changed out the pick up coils with the wiring.. I'll try my grounds and clean them
  5. dustball
    dustball Member
    Oak Harbor, WA
    GOT IT!!!!!! I was wondering what was up... there was a small amount of paint where the coil fits to the frame.. also the cdi and all the connections had small amounts of green corrosion on them... I cleaned it all up with an acid brush and isopropyl alcohol and viola!! Fires up.. hopefully for good this time... it always seems when it got warmed up after a ride then it would cut out
