Something with the clutch? Or clutch cable? Help.
Discussion in 'XJ Technical Chat' started by snowridr182, Mar 22, 2008.
  1. snowridr182
    snowridr182 Member
    Bellingham, WA
    So I need some help with this...my bike has been running pretty good lately except for this one problem. When I turn my bike on and pop it into first gear it kind of jumps a little and doesn't feel smooth. Also sometimes when I am driving and down shift into first gear, once again it feels rough and sometimes (possibly when I don't fully pull the lever all the way to the handle bar) it grinds a little bit. Is my cable not tight enough? Any suggestions on what it might be and how I can fix it?
  2. capy
    capy Member
    Florida
    You need to tighten the cable adjuster on the lever mount. I would be more concerned with it going in and out of neutral smoothly. When it will do that, it should go in and out of 1st smoothly also.
  3. PainterD
    PainterD Active Member
    St. Cloud, Minnesota
    It's just a simple cable adjustment that needs to be done. You need to put more "pull" on the cable, so turn the adjuster up by the lever out. You should still have a little free play on the lever (not very much) so the clutch does not start to slip.
  4. snowridr182
    snowridr182 Member
    Bellingham, WA
    So do I want to spin it in the direction of the adjustment arrow or in the opposite direction?
