Sorry, meant to post a reply to another thread.
Discussion in 'XJ Technical Chat' started by tinwakr123, Feb 1, 2008.
  1. tinwakr123
    tinwakr123 Member
    I would like to know this also, my ignition switch is getting pretty funky in that the key sometimes turns the switch, sometimes I have to play with it to get it to turn. I can remove the key from the ignition switch too with the bike running.
    Thanks,
    Chuck
  2. RickCoMatic
    Replace the Ignition Switch.
    The Ignition Switch tumblers are getting worn-out to the point where any object inserted into the Ignition Switck Key Slot will turn the switch and allow the Bike to be started.
    Replacing the whole Ignition Switch will be LESS expensive than having your Ignition Switch repaired.
    The amount of Labor involved will be the same because the Ignition Switch Assembly will have to be removed and replaced.
    Replacing it with a New Switch will save the additional cost of having your Switch overhauled by a locksmith.
    You should be able to fine an OEM Factory Ignition for under 50-Dollars.
  3. tinwakr123
    tinwakr123 Member
    I am scared to go to my local Yami dealer to get a new switch, they will likely charge me an arm and a leg. Where do you sugget getting one of these ignition switches other than the dealer?
    Thanks,
    Chuck
  4. RickCoMatic
    Online.
    You don't need the Dealer.
    Any Bike Shop will have them; too.
    Ignitions are a Part that is almost Universal, not to just Yamaha ... but across Manufacturers, too.
    Oldbikebarn.com
    parts'nmore
    cyclewareables
  5. tinwakr123
    tinwakr123 Member
    Thanks Rick I will check out the places you have recommended and also other places here in Waterloo.
    Chuck
  6. schmidtap
    schmidtap Member
    Ft Stewart, GA
