Speedo issues
Discussion in 'XJ Technical Chat' started by dazed, Aug 2, 2010.
  1. dazed
    dazed Member
    Ft Atkinson, WI
    Hello everyone, if this is posted so where buried in the forms i apologize. I am having issues with my speedometer. It will not kick on until im going at least 30mph, and once i am going 45mph+ the needle has alot of play, bouncing almost freely for 5-10mph. I replaced the cable with a brand new OEM cable it helped slightly but the same issues apply. Any suggestions? :?:
  2. bigfitz52
    Time to have a whack at the clock itself: http://xjbikes.com/Forums/viewtopic/t=15303.html
    I believe you have cluster-mounted instruments so access will be a breeze.
    Be sure to go SPARINGLY with the lube; I need to practice what I preach.
  3. dazed
    dazed Member
    Ft Atkinson, WI
    Thanks Wizard, looks like I'll give this a try
