Speedometer howling.
Discussion in 'XJ Technical Chat' started by Jetfixer, May 14, 2017.
  1. Jetfixer
    So great sunny warm day for a change and wife told me to go fora ride:D Take off bike running great get 45 miles out stop a light ...What is that noise? Oh I know what it is SPEEDO nurse it home needle vibrating but still registering. Get . me disconnect cable and as expected noise went away... pull cluster tore down pulled speedo...the flywheel barely turns .Lubed and worked it back and forth a few times reassembled and drum roll it works as it should no howling :) but it is now cooling off so I decided to call it a day got 72 miles today. I have fixed a few speedos on my Vw's so if your carefull it can be done.
  2. Wintersdark
    Wintersdark Well-Known Member
    Calgary, Alberta, Canada
    Hazzah!
    Just had exactly the same thing happen to me a couple minutes ago. Got off the freeway on my way to work, popped open my visor as I slowed from way-way-fast to merely way-fast and was greeted by this crazy howling matching bike speed but not RPM. After a panic filled check for something rubbing on my tire (I've never heard a speedo do that before), a quick bit of feeling about after I got moving again quickly showed the speedo to be the culprit.
    Anyways, a couple questions good sir: what lubricant would you recommend, and any pointers for one who's never seen the inside of a mechanical speedo before?
  3. Jetfixer
    On the Maxim pull 2 bolts on headlight bucket pull it away there should be 2 bolts on cluster remove them pull up and remove cover on back of cluster . Remove the trip odometer needle turning backwards there are some screws on back of speedo , once pulled speedo should come free of cover DO Not touch face of speedo ( finger prints are not nice to look at when you can't get to them after your done lol) look at back of speedo you will see a small fly wheel if it is starting to seize it will be difficult to turn. I used a nozzle and PB blaster short spray , worked it back and forth till it turned freely , and put a light smear of grease on the drive gears . Put is back tougher and she is nice and quite now. My Seca has a different cluster but the Maxim is similar . Just be gentle with this there is a spring you don't want to disturb so Do Not pull on the needle!!!
    Wintersdark likes this.
  4. Wintersdark
    Righto, sounds pretty straightforward. I'll give it a go this afternoon. Thanks!
  5. Jetfixer
    Took it out crancked it up to 75 and rode around low speed 30 and no noise... so for now I'll call it "fixed"
  6. Door dude
    Door dude Active Member
    Mountain Home Arkansas
    Ive got a speedo that runs about 5 mph slower... can anyone help ?
  7. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
    Ride 10mph faster?
    Door dude, Jetfixer and Wintersdark like this.
  8. Wintersdark
    This is a good solution to practically any problem :)
    Jetfixer likes this.
