Speedometer showing wrong speed
Discussion in 'XJ Technical Chat' started by Doug, Mar 11, 2009.
  1. Doug
    Doug Member
    Hamilton Ont
    I,was riding and was flying by cars ,I looked at my speedometer and it showed I was doing the legal limit , I assume that my speedometer is out of wack,any reason for this? and can it be corrected ?? thanks ..
  2. bigfitz52
    It's most likely gummed up and could use a good clean and lube.
    How to do that is here: http://xjbikes.com/Forums/viewtopic/t=15303.html
    That's once you get TO the instruments. Unfortunately, on your bike, I believe you'll have to slice the plastic inner "cans" open to get at the instruments. You may be able to go in thru the lamp holes but I don't know for sure.
    Or eBay another one and hope it's not gummed up too.
    Warm weather should help, by the way.
  3. flash1259
    flash1259 Member
    W.R. Wisconsin
    you could get a police officer to comfirm the speed you are riding at . they will more than happy to help you.
    Anf bigfitz gives you a good tip . clean up the speedometer gear at the wheel and use new grease also clean and lube the cable someone here cleanedup all his cables but i can't recall who
  4. bigfitz52
    Unfortunately a gummed up cable will cause jumping but not a steady mis-read.
    You should by all means clean and lube the cable and the gearbox; you may still need to attend to the instrument itself.
    Another of our members posted a photo how-to when she cut her instruments open but I can't find it.
  5. tumbleweed_biff
    tumbleweed_biff Active Member
    Gahanna Ohio
    Doug,
    I have the same problem with my XJ650. Last year I was told that there was no calibration that could be done with the speedometer. I was also told that in 5th gear the speed of the bike was pretty close to actual speed so that at 6000 RPM you are going 60 mph ... I plan to have my wife check my speed as soon as I get on the road this spring to confirm.
